HS-125 oil leak
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HS-125 oil leak
Page: [1]
Login
HS-125 oil leak - 9/12/2002 11:23:38 PM
Brian C.
Status: offline
Mike,
I have 2 HS -125 servo. I noticed one thing on the HS-125 servo I try to install last weekend. I lay the servo down on the wing and noticed a oil spot after I pick up the servo. There is a oil seeping out around the label. I tried to remove the label to get more thinner to fit the servo in the stabilizewr. The label just popped off when I picked at it with a knife. I found the back of the label was oil soaked, either from the motor or the feed back pot openning on the case. Is this the grease liquified or something else??
I wonder how this will affect the feed back potentiometer? Since oil and carbon dust can form a nice abbrasive compound and remain within the pot casing.
Any Idea??
Brian
_____________________________
Brian, An EAJ
       Post #: 1
HS-125 oil leak - 9/13/2002 8:49:52 PM
MikeMayberry
Status: offline
I have no idea... there should be no oil in the servo. The only thing I can think of is the servo grease?
I'll check into it further.
Mike.
(in reply to Brian C.)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.094RCU1
