TManiaci
CA, USA Status: offline
We finally went out and got a flight in with the new Dymond COOL S 4200 setup, ran it with a TP1320 on a APC 9x3.8 prop, pulling 13.6A. All I can say is WOW! Was windy at dusk, really a little too windy to fly, but we have been waiting so long to get her up, I couldn't wait any longer. Took off on high rates, flying REALLY nice, and making low slow passes into the wind and pulling it verticle WOT, DAMN this thing is really strong now, and WAY more quiet that the stock setup. Very pleased, and it's way under prop'ed for the TP1320 (can pull 15 amps, with 20 amp burst). It's nice having landing gear, and the design I put in is really flexible for those "hard" landings. Took it like a champ. Snaps and rolls on high rates are real quick. Downwind the wings bobble a lot, and trying to hover up high in the wind was a ****, but about 1/2 throttle, nice. Pulls out of a hover real agressivly now. Nice for recovery. I snapped the plane REAL hard a few times, no evidence of any wing folding or odd behavior. All the bracing has made it pretty solid. Going into the wind, a slight climb and the wind gets under the wing and it goes vertical all by itself... a little frustrating, but fun. Still shaking (like doing a maiden), we have not had it up in 5 weeks or more. So little time, and so much wind. Still flying a little fast, need to adjust the ailerons to give a little flap I think. Landings are still pretty hot, and you have to jocky the throttle to keep her decent right. With only 4-5 flights, still feeling it out. It's definitly better with the lighter battery. Got a Dymond 15C 3S 1500 mAh Lipo on the way. Should be HOT in this thing, prop it back up to 10x4.7 or better I think. Will pull 22 amps and will be monster overpowerd then, not that it needs it. The setup I flew tonight is really a good match, and should fly 16-18 minutes on the TP1320. Anyway... this Dymond brushless gearbox rig is the sh-t. Definitly a must-have on this plane if you want MORE POWER.
_____________________________
TMan
