AcroJo
Joined: 1/25/2003 From: Clarks Summit, PA, USA Status: offline
quote:
ORIGINAL: EVOL well i dont know about you guys but $65 is a lot to spend if the plane is no good at what it is advertised to do. its marketed as a 3D plane and so far there are only negative reports from people who flew them. take your $65 plus li-po battery $45, charger $130, receiver and servos $90, and a speed controller $50. this is assuming your not going to put a brushless in it. i love great planes and i have 3 of thier kits im flying right now but if this plane sucks than everyone should have a right to know about it. i would really like to see a video. EVOL $65.00 is considerable, but you can't figure in the cost of the gear, as it will work in any other plane. As far as evaluations go, I think peoples opinions must be taken with a grain of salt. The common scenario is, buy a kit, dump the box, assemble it and fly. IT FLIES LIKE CRAP!!!!!!!!! I will maiden a plane for the first dozen flights. Fly, observe and tweak it untill its right. Then you get the quality issue, it hit the ground and broke. ITS A PIECE OF CRAP!!!!!!! If you smack the ground then you deserve to spend a little time and glue to fix it. THE LANDING GEAR SUCKS!!!!! Simple solution, learn how to land. If you can't float in a couple ounces of foam without damage, then hand the box to someone that can. Is there really only a handfull of consumers out there that realize we are dealing with foam here? To those of you that understand what I'm talking about, I apologise for the rant. Joe
_____________________________
Stranger in a strange place.
