RE: Sig 1/4scale C/W Cub build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig 1/4scale C/W Cub build Page: <<   < prev  84 85 [86] 87 88 89 90 91 92 93   next >   >>
Login
RE: Sig 1/4scale C/W Cub build - 8/30/2012 3:10 PM
Cub Man
Score: 100
Last Login: 5/24/2013
Status: offline
i think so
_____________________________
The Cub Den, www.thecubden.org
Cub Brother #1 Ultimate Brother #3 Waco Brother #120
Hide Signatures
(in reply to Cub Flyer Fresno)
       Post #: 2126
RE: Sig 1/4scale C/W Cub build - 9/6/2012 3:59 PM
mrdhud
Score: 110
Last Login: 5/23/2013
Status: offline
Hello all,
If you haven’t seen Cub Mans posts (post 608) on the Cub Brotherhood forum have a look. http://www.rcuniverse.com/forum/m_10786306/mpage_25/key_/tm.htm
If you have benefited by his website perhaps a little assistances would be in line about now.
Dan Hudson WACO Brotherhood #45
GIT-ER-DUN "Build a WACO"
Hide Signatures
(in reply to Cub Man)
       Post #: 2127
RE: Sig 1/4scale C/W Cub build - 9/7/2012 12:07 PM
VincentJ
Score: 145
Status: offline
Thanks Dan for posting that information and I couldn't agree with you more it's time to wave the rally flag and help out!!!
VJ
Hide Signatures
(in reply to mrdhud)
       Post #: 2128
RE: Sig 1/4scale C/W Cub build - 9/8/2012 2:45 AM
Cub Flyer Fresno
Score: 115
Status: offline
Changing the subject back to... well... the subject...   VJ, have you considered what engine you will be using to replace the DLE20?  I would really like to see one that will fit "under the hood".  So, any ideas?
Take care,
David
Cub Brotherhood #65
Hide Signatures
(in reply to VincentJ)
       Post #: 2129
RE: Sig 1/4scale C/W Cub build - 9/8/2012 4:25 AM
Cub Man
Score: 100
Status: offline
I have a Evolution G26 Gas burner under the hood on my L-4. The plane is around 17 pounds. Power is great I can fly it scale but also has a little extra power to use if needed. This fits total under the hood except for the plug. Now for the issues I have. The carb sets in front of the engine like a glow. It is the standard big carb as most gas engines. This blocks what little air that comes thru the holes in the front of the cowl. With that said this runs hot when it is coweled in. with this said, I have just built from 1/64 ply a shroud from the side and have a small pc fan mounted to blow air across the head. This is a 5 v fan so it will run off of my 4 cell ignition pack. I have yet to give it a try, hope to try it this weekend due to a event at our filed next weekend.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 2130
RE: Sig 1/4scale C/W Cub build - 9/8/2012 11:41 AM
VincentJ
Score: 145
Status: offline
David, I have been looking at the DLE30  for a possible fit  of course that is going to mean some firewall movement   .  Oh well just more work.  I haven't repaired the wing tip yet.  Going to tackle it this winter.  Right now I have a new build on my table (Sig Ryan STA) which has really gotten me out of my funk so to speak.  Here is the thread if your interested in checking it out                  http://www.rcuniverse.com/forum/m_11208903/tm.htm
VJ
Hide Signatures
       Post #: 2131
RE: Sig 1/4scale C/W Cub build - 9/8/2012 5:16 PM
SunDevilPilot
Score: 147
Status: offline
CubMan.....  What tires do you have on the Cub you just posted a photo of?  They look like 1/4 Cub tires and they look like they may be air filled / soft.
SunDevilPilot
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
       Post #: 2132
RE: Sig 1/4scale C/W Cub build - 9/9/2012 3:51 AM
Cub Man
Score: 100
Status: offline
SunDevilPilot they are a set of the good old dubro cub wheels. They are air filled. yes I have to pump them up a couple times a year but love then 10 time better then the foam version. `Keep an eye out on ebay for them. Wish dubro would bring them back!!!!!!!!!!
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 2133
RE: Sig 1/4scale C/W Cub build - 9/9/2012 5:09 AM
SunDevilPilot
Score: 147
Status: offline
quote:
ORIGINAL: Cub Man
Im jealous!
I have a set of 6" Dubro "balloon" tires that Dubro renamed "Tundra Tires".  I was having ground handling problems with them on so I removed them and installed the stock foam Dubro 1/4 Cub tires.  The handling problem was corrected but they are foam and wear rather quickly doing long touch-n-goes on asphalt.
Thanks for the info!
SunDevilPilot
SunDevilPilot
Hide Signatures
       Post #: 2134
RE: Sig 1/4scale C/W Cub build - 9/9/2012 11:24 AM
RC_AVIGATOR
Score: 100
Last Login: 5/11/2013
Status: offline
quote:
ORIGINAL: Cub Man
Off the subject, what prop nut assembly is that in this picture?
Mike Rowe
Hide Signatures
       Post #: 2135
RE: Sig 1/4scale C/W Cub build - 9/9/2012 11:46 AM
WacoNut
Score: 175
Status: online
I had Dubro foam filled tires on my 1/4 Cub and they did fine but I was always flying from grass. I also have them on my 1/3 Cub.
I have my planes loaded in the trailer and I will be spending the day at the field. I haven't flown the 1/3 Cub for about 2 months, time to get some air under it wings.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to RC_AVIGATOR)
       Post #: 2136
RE: Sig 1/4scale C/W Cub build - 9/9/2012 2:41 PM
SunDevilPilot
Score: 147
Status: offline
quote:
ORIGINAL: RC_AVIGATOR
quote:
ORIGINAL: Cub Man
Not sure if this is what he has but Sierra sells some.
http://www.sierragiant.com/prod43.html
SunDevilPilot
SunDevilPilot
Hide Signatures
       Post #: 2137
RE: Sig 1/4scale C/W Cub build - 9/10/2012 2:21 AM
Cub Flyer Fresno
Score: 115
Status: offline
quote:
ORIGINAL: VincentJ
I'm seriously considering the DLE30 as well.  Pretty sure the plug will hang out but hey, it'll keep the plug cool.  I've already moved my firewall back, I'd just have to put a hole in it for the carb.
Now all I need is some money.......   DOH!!!!
Cub Brotherhood #65
Hide Signatures
       Post #: 2138
RE: Sig 1/4scale C/W Cub build - 9/10/2012 2:46 AM
cannonball200
Score: 105
Last Login: 5/18/2013
Status: offline
SunDevilPilot, Dubro still sells the J-3 Cub air up valve treaded tires/wheels/cub hub cap. You will have to call them direct as they cannot advertise them or sell through a dealer because goodyear had a dispute with them over putting the goodyear name on the tire. I bought a set some time back by calling them about a set. I just bought a set on ebay a couple of months back for my H9 J-3. They work so much better on landings to soften it out along with the bungee gear.
Eddie
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
       Post #: 2139
RE: Sig 1/4scale C/W Cub build - 9/10/2012 2:50 AM
SunDevilPilot
Score: 147
Status: offline
quote:
ORIGINAL: cannonball200
Eddie
I'll given them a call tomorrow and see what they can do!  Thanks for the info!
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to cannonball200)
       Post #: 2140
RE: Sig 1/4scale C/W Cub build - 9/10/2012 5:04 PM
Cub Man
Score: 100
Status: offline
RC_AVIGATOR Take a look at http://www.vaillyaviation.com/Intro.html they have a 1/5 scale prop nut that I used. Had to do a little work to it, but was able the thread the hole int he center and just screw it on the motor shaft.
Hide Signatures
       Post #: 2141
RE: Sig 1/4scale C/W Cub build - 9/11/2012 4:05 AM
cannonball200
Score: 105
Status: offline
Did Dubro have the cub air-up tires still?
Eddie
cannonball200
Hide Signatures
       Post #: 2142
RE: Sig 1/4scale C/W Cub build - 9/11/2012 4:17 AM
SunDevilPilot
Score: 147
Status: offline
Eddie
I was out flying too long to call today, I will tomorrow.
I'll let ya know.
SunDevilPilot
SunDevilPilot
Hide Signatures
       Post #: 2143
RE: Sig 1/4scale C/W Cub build - 9/11/2012 7:57 PM
cannonball200
Score: 105
Status: offline
SunDevilPilot, I called Dubro about the 1/4 cub air-up tires/wheels/hub caps set. He said they had a few sets left and when they are gone thats it- no more. He said there was no dispute with Goodyear on that product, they just started making the foam products which are lighter which he said everyone wants lighter.
He said the pricing would be the same as the 1/4 foam set.
Eddie
Click for fullsize
cannonball200
Hide Signatures
       Post #: 2144
RE: Sig 1/4scale C/W Cub build - 9/12/2012 1:06 AM
SunDevilPilot
Score: 147
Status: offline
Eddie
I got too busy today to call but I see you did.  I will call, hopefully tomorrow, and order a set.  Thanks for making the inquiry!
SunDevilPilot
SunDevilPilot
Hide Signatures
       Post #: 2145
RE: Sig 1/4scale C/W Cub build - 9/12/2012 1:13 AM
cannonball200
Score: 105
Status: offline
SunDevilPilot,
Your welcome!
Eddie
cannonball200
Hide Signatures
       Post #: 2146
RE: Sig 1/4scale C/W Cub build - 9/12/2012 3:52 AM
SunDevilPilot
Score: 147
Status: offline
I just finished up a prototype set of bungee covers for my Sig 1/5th Scale Cub.  I would like to find some vinyl type material when I make a set for my 1/4 Cub.
The covers slip over the bungees then the ends are cinched down with small zip Ties.  The zip ties can be replaced when the bungees need servicing.  The o-rings and rubber bands really take a beating when they are fully exposed.
The covers are wide enough to allow for the movement of the bungees as the bumps are absorbed by the gear.
Once I make some for my 1/4 Cub, and determine the dimensions, I will make some extra for you guys with the Robart Gear.
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
SunDevilPilot
Hide Signatures
       Post #: 2147
RE: Sig 1/4scale C/W Cub build - 9/12/2012 12:24 PM
WacoNut
Score: 175
Status: online
SDP,
I made a set for my 1/3 from Black Nylon. I do not have to worry about O-rings as my gear has springs so I used 1/16" elastic cord sewed into the ends to tie it to the gear legs. The nylon is flexible enough to give it a more scale look on the gear.
Later!!
Anthony
Hide Signatures
       Post #: 2148
RE: Sig 1/4scale C/W Cub build - 9/12/2012 1:53 PM
Cub Man
Score: 100
Status: offline
Guys I have covers on my site made from rip stop nylon for $10 a set shipped.
Hide Signatures
(in reply to WacoNut)
       Post #: 2149
RE: Sig 1/4scale C/W Cub build - 9/12/2012 3:47 PM
SunDevilPilot
Score: 147
Status: offline
I called Dubro this morning. Very nice people!
I ordered two pair of the air filled Cub Tires.
Thanks again for the info on how to order them.
SunDevilPilot
SunDevilPilot
Hide Signatures
       Post #: 2150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
