Byron P-51 cg
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Byron P-51 cg
Page: [1]
Login
Byron P-51 cg - 9/16/2002 6:36:17 PM
F106A
Status: offline
Hi everyone,
The instructions say 5 1/2" from the LE at the root. When I project it out it's 3" from the LE at the end of the f/g stub wing. It takes 2#'s of lead to balance it. Eyeballing the cg at this location just seems to far forward, looks like it should be about 1 1/2" further back. Can anyone give me their location at the stub and if they had to add this much weight. Total a/c weight is 26 pounds.
Jon
       Post #: 1
CG - 9/16/2002 6:52:27 PM
kram1234
Status: offline
I'm looking at the directions right now and it says, somewhat ambiguously, that the CG is "located approximately 5 1/2" from the leading edge of wing at the [SIZE=3]center [/SIZE] section." It does not say the wing root but is still a bit unclear. I've yet to build mine so I can't be of much more help to you, sorry!
Mark
(in reply to F106A)
       Post #: 2
Byron P-51 cg - 9/16/2002 9:07:28 PM
F106A
Status: offline
Hi,
My c/g has to be wrong; at the location I projected the landing gear is behind the c/g.
Jon
(in reply to F106A)
       Post #: 3
P-51 CG - 9/21/2002 2:30:52 PM
Jimmy Bananas
Status: offline
Jon:
Try it this way...the front egde of the canopy,where it fits onto the fuse (Fuse is recessed for the canopy), the CG is 3/32" behind that line..that is the CG where mine is...when I got mine 7 years ago,the hole was drilled out for the CG....Best to drill hole halfway down between canopy and wing fillet...good luck
(in reply to F106A)
       Post #: 4
P-51 CG - 9/21/2002 2:43:50 PM
Jimmy Bananas
Status: offline
Jon:
Forgot to mention,,this is the CG for the newer version of the P-51...has wing panels,not a one piece wing...................
(in reply to F106A)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.392RCU4
