What adhesives do I use
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> What adhesives do I use
Page: [1]
Login
What adhesives do I use - 3/2/2005 1:32:07 PM
acerpal
Status: offline
I am in the process of building a cockpit for a P40. I will be using a variety of materials which need to be glued together. I will be using ply, balsa, styrene I have no idea of how to glue styrene to balsa or ply. Any suggestions would be appreciated
       Post #: 1
RE: What adhesives do I use - 3/2/2005 2:00:49 PM
ifixairplanes
Status: offline
If it is non structural then I would use 5 min epoxy. Although recently I have discovered gorrilla glue, so I probably would be using that, it's awsome stuff!
Sean
_____________________________
"We request that model aviation not be innocently sucked into a black hole of regulation..."
(in reply to acerpal)
       Post #: 2
RE: What adhesives do I use - 3/2/2005 6:01:00 PM
TomCrump
Status: offline
I've had good luck gluing styrene to wood with medium CA.
Tom C
(in reply to ifixairplanes)
       Post #: 3
RE: What adhesives do I use - 3/2/2005 6:17:13 PM
ifixairplanes
Status: offline
Isn't styrene styrofoam??? I've had goodluck melting styrofoam with medium CA!
Sean
(in reply to TomCrump)
       Post #: 4
RE: What adhesives do I use - 3/2/2005 7:32:39 PM
Deadeye
Status: offline
quote:
ORIGINAL: ifixairplanes
Sean
Nope. It may share some chemical properties, but it is a plastic unaffected by medium CA. Acetone will disolve it. Thin CA may disolve it as well. The adhesive that Plastruct reccomends is a acetone type solvent that bonds styrene to styrene very well. But, not styrene to balsa.
Whatever the case, you are looking at a mechanical bond. If it were me, I'd use polyurethane glue after scuffing the styrene with 80 - 100 grit. CA might fog what you don't want fogged.
Randy Rossmiller, proud husband of Terrorist Hunter www.shannenrossmiller.com
       Post #: 5
RE: What adhesives do I use - 3/2/2005 8:22:37 PM
ifixairplanes
Status: offline
Thanks for the clarification deadeye.
BTW: Gorrilla glue is a type of polyurethane glue
Sean
(in reply to Deadeye)
       Post #: 6
RE: What adhesives do I use - 3/2/2005 8:29:39 PM
Deadeye
Status: offline
Sean
Roger that. I think it is exactly the same from what I have read. I use the Elmers poly, and it costs about 1/3 less than Gorilla Glue. Great stuff, tough as nails, light, sandable...truly the 'ultimate' glue. Now if they could just figure out a fast dry formula...
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.454RCU4
