Amoore
Hey Guys! I highly recommend this charger. Does it all really. Nicads just plug it in and push a button and go fly with your other pack. However, I noticed one of you mentioned the cutoffs were only 3mv apart for nicd and nimh so using the auto charge function wouldn't hurt with nimh. I would advise against this, you'll never get a full charge with the nimh if you try to "Peak" charge it like a nicd. Reason: When Nicads reach peak charge there will be a relatively quick and large (in millivolt terms) drop in peak voltage, hence the term peak charging and it goes only with nicds. So, in peak chare mode (Auto) mode this charger will peak charge whatever you put on it. Nicds that's perfect. However, nimh packs have a generally lower voltage than nicds, and more importantly, they will reach this peak voltage rather quickly. BUT, the nimh pack will still be sucking up the mahs, in other words, it's still needs to charge to full capacity even though the voltage has peaked. SO you can see, if you put a nimh pack on a nicd peak charger, the charger will recognize the peak voltage drop (Which occurs before a full charge on nimh) and shut the charging current off. So yeah, the battery will act like its charged but will soon drop. Be warned of the cheaper chargers that claim they are "Peak" detectors and charge nimh packs! The SuperNova owners manual is excellent and explains this much better than my feeble attempt, and the manual mode allows you to setup the charger for each specific pack and type you have, then you're assured of a full charge. This charger has never failed me or "falsely peaked" any type of battery I've used. Another Note: Since NIMH packs reach close to peak voltage earlier in the charge cycle, they are naturally going to be warmer to the touch than a nicd. So don't worry about it. Hope this helps you buy this charger it's great and no I'm not a rep for the company just a satisfied consumer. Aaron
