RE: Cap 232 Profile ARF "Subaru Style"    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Cap 232 Profile ARF "Subaru Style"
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Cap 232 Profile ARF "Subaru Style" - 4/8/2005 4:08 PM
kolarshooter
Score: 100
Last Login: 1/5/2010
Status: offline
I swapped out the stock wire LG for composite ones I found at OMP
Improved ground handling immeasurably.
_____________________________
JR 9303; DX-7; 34% CA Extra 300L/DA100; H-9 33% Edge 540/DA100; EF Edge Profile/S-72; Reactor/S-91; Foamies
Hide Signatures
(in reply to kolarshooter)
       Post #: 26
RE: Cap 232 Profile ARF "Subaru Style" - 5/1/2005 6:09 AM
jmess73
Score: 100
Last Login: 8/6/2007
Status: offline
I finally flew my Subaru, it flies great, but way overpowered with the Saito 100. I kind of figured it would be so no surprises there. I'm looking for a Saito 82 now, so I can put my 100 in a H9 Corsair, but I can get a better deal on a new 100 than a new 82, go figure. Hey kolarshooter how's your covering holding up, as you know I recovered the fuse, but I still think the covering on the wing sucks, it feels very flimsy, I was just wondering if you noticed any problems with peeling punctures etc...
Jeremy
Hide Signatures
       Post #: 27
RE: Cap 232 Profile ARF "Subaru Style" - 5/1/2005 3:51 PM
kolarshooter
Score: 100
Status: offline
I had mine out last week and again yesterday. Covering is fine.
Saito 100...that must be sick!! I guess that you might look for a 72 or 82 (I'd buy an 82...unless the 72 was a super good deal.)
Mine flys great...if you ever put the smaller Saito in it, you'll certainly notice the improvement in wingloading.
Keep in touch.
Hide Signatures
(in reply to jmess73)
       Post #: 28
RE: Cap 232 Profile ARF "Subaru Style" - 5/1/2005 5:03 PM
jmess73
Score: 100
Status: offline
Did you change the tail wheel too, or just the mains?
Jeremy
Hide Signatures
       Post #: 29
RE: Cap 232 Profile ARF "Subaru Style" - 5/1/2005 9:42 PM
kolarshooter
Score: 100
Status: offline
Tailwheel is Dubro 60 size.
Mains are OMP. They are quite tall for a .40 size bird in my opinion, but they sure give me lots of room to prevent prop-strikes!
I just saw some other e-bay profile birds...HERE
Hide Signatures
       Post #: 30
RE: Cap 232 Profile ARF "Subaru Style" - 5/2/2005 1:11 AM
jmess73
Score: 100
Status: offline
Well I flew my Subaru again today, this thing will hover at just a couple clicks over idle!! No joke I'm serious! This engine is way too big I LOVE IT!!! . I did cave in the main wheels today though, I guess I'll be oredering the OMP gear after all.
Jeremy
Hide Signatures
       Post #: 31
RE: Cap 232 Profile ARF "Subaru Style" - 5/2/2005 2:55 AM
kolarshooter
Score: 100
Status: offline
The wire gear is a joke. You won't regret getting the OMP gear.
Hide Signatures
       Post #: 32
RE: Cap 232 Profile ARF "Subaru Style" - 5/21/2005 5:53 AM
jmess73
Score: 100
Status: offline
Well the weather finally cooperated enough to fly the Subaru with it's new wheels, a huge improvement over the stock ones! I have to say i love this engine combo, what a thrill!! It has so much power on tap you always get instant response, it s really fun. I didn't have any rough landings so i don't know exactly how strong these new wheels are but they seem really tough, perfect for botched harrier landings LOL!! The dubro tail wheel helped ground handling tremendously too!
Hide Signatures
       Post #: 33
RE: Cap 232 Profile ARF "Subaru Style" - 5/21/2005 2:26 PM
kolarshooter
Score: 100
Status: offline
This IS a fun plane, no doubt!
Hide Signatures
       Post #: 34
RE: Cap 232 Profile ARF "Subaru Style" - 6/26/2005 5:42 AM
jmess73
Score: 100
Status: offline
Flight update! This plane is HUGE fun! On the down side though, the new gear is way stronger... maybe too strong? I had a dead stick landing and the gear just clipped the top of the hay that rings the runway, and they tore off, leaving quite the gaping hole in the bottom on the fuse! I realize it's my fault, trying to keep a very low idle because of the oversized engine, and once in a while I stall it!!! Maybe a tougher wire set would have been better for me, or maybe the planes light weight reflects it overall strength. It's possible I'm just an idot too It just didn't seem like a hard enough hit to do the damage it did, I don't know, regardless my planes broken
Jeremy
Hide Signatures
       Post #: 35
RE: Cap 232 Profile ARF "Subaru Style" - 6/27/2005 4:39 PM
kolarshooter
Score: 100
Status: offline
OK...Here's what I do for that:
I use a Throttle - Throttle mix on my JR Transmitter and have it on an assignable switch. I flip the switch to increase my idle by 500 RPM (or so) so that flying aerobatics and such doesn't cause the engine to stall.
Ready for final approach? Just flip the switch back and the idle comes down to its previous setting.
There ya go!
Hide Signatures
       Post #: 36
RE: Cap 232 Profile ARF "Subaru Style" - 6/28/2005 2:06 AM
jmess73
Score: 100
Status: offline
Sounds like a good idea, I'll have to look into it. I also need to change my prop, I have a 13x6 on it now, I think I'll change to a 14X4maybe even a 15X4. it'll slow down my speed and let me idle up a little
Jeremy
Hide Signatures
       Post #: 37
RE: Cap 232 Profile ARF "Subaru Style" - 7/4/2005 8:28 AM
knighttwister
Score: 100
Last Login: 3/21/2013
Status: offline
i bought one of these on ebay also. the covering on mine was perfect. no hassles what so ever. i plan on a magnum 52 four stroke. do you think that will be enough? i'll use a 13X4 prop. the bolt holes line right up for it.
i put the thing together today, and it only took about 2 1/2 hours minus the engine. the channel for the servo wire through the fuse is a great idea. it's got morris beat hands down.
Hide Signatures
       Post #: 38
RE: Cap 232 Profile ARF "Subaru Style" - 7/4/2005 9:19 AM
jmess73
Score: 100
Status: offline
Its a very light plane, so you should be allright, you loose some vertical performane though. Change the gear though the stock ones aren't even worth the aggravation of assembly.
Jeremy
Hide Signatures
       Post #: 39
RE: Cap 232 Profile ARF "Subaru Style" - 7/4/2005 4:35 PM
kolarshooter
Score: 100
Status: offline
I agree with Jeremy...your motor will fly the plane around just fine. It might not hover, but there's more to flying than hovering, huh?
Landing gear is a Joke. OMP has reasonably priced replacement gear. I posted the URL in one of the above posts. I used the dubro .60 size tailwheel kit. Pretty necessary unless you fly off of grass...then, I don't know (I've never flown from grass.)
I flew mine yesterday. Definitely not a Pattern plane...but a really fun "knock-around" plane which, when adequately powered will 3D 'till your thumbs fall off.
Did you get it on e-bay recently? Jeremy and I bought our months ago then they were no longer available. I'd be tempted to get another to keep around as a spare. Great flying plane...even better than the Accell Katana I had.
Have fun!
Hide Signatures
(in reply to knighttwister)
       Post #: 40
RE: Cap 232 Profile ARF "Subaru Style" - 7/5/2005 2:25 AM
knighttwister
Score: 100
Status: offline
i bought it over the winter months and it was sitting on the shelf until three days ago when i finished my goldberg chipmunk. i like to have something on the bench at all times, just so it looks like i'm doing something when the lady of the house gets in my hair and i need a reason to get away.(not really just in case she reads this)
Hide Signatures
       Post #: 41
RE: Cap 232 Profile ARF "Subaru Style" - 7/5/2005 6:30 AM
srg123cohen
Score: 100
Last Login: 3/7/2007
Status: offline
I found the website...but its in japanese damn .....but i got a translation YES but i cant figure out how to order models.
I like them thin 1%ers ALL THE WAY
Hide Signatures
       Post #: 42
RE: Cap 232 Profile ARF "Subaru Style" - 7/17/2005 10:27 PM
jmess73
Score: 100
Status: offline
Well I put the wheels back on, I fixed the broken part of the fuse, then I epoxied a 1/16 ply skin to both side all the way back to the CG. If that doesn't strenghten it up nothing will!!! I flew it today and its still a blast, the ply reinforcing made a huge difference coping with all the vibration coming off that huge engine.
Jeremy
Hide Signatures
(in reply to srg123cohen)
       Post #: 43
RE: Cap 232 Profile ARF "Subaru Style" - 7/17/2005 11:11 PM
kolarshooter
Score: 100
Status: offline
flew mine wednesday. Fun fun fun!
Hide Signatures
       Post #: 44
RE: Cap 232 Profile ARF "Subaru Style" - 9/26/2005 5:33 AM
kolarshooter
Score: 100
Status: offline
knightwister, I tried to reply to your PM but my message was bounced back with a note that you either cannot or choose not to receive PMs. I hope you are subscribed to this thread so you get this message.
Hide Signatures
       Post #: 45
RE: Cap 232 Profile ARF "Subaru Style" - 8/21/2007 4:24 AM
SunShyne
Score: 120
Last Login: 5/17/2013
Status: offline
sorr yo to bring back a 2 year old thread but I bought one last year and am now finally getting around to putting it together I am confused on the servo exit holes in the fuse where the rudder and elevator servo wires exit from. Where the heck do i channel them into the wings? I dont see anything obvoius.
Anyone still flying theirs?
Revver Bro #86
Visit RCU''s E-flight Only Website: www.WattFlyer.com
Hide Signatures
       Post #: 46
RE: Cap 232 Profile ARF - 10/21/2010 7:15 PM
Tom Nied
Score: 100
Last Login: 5/24/2013
Status: offline
Very informative. Thanks for sharing.
Hide Signatures
(in reply to SunShyne)
       Post #: 47
RE: Cap 232 Profile ARF - 10/22/2010 3:37 AM
Tom Nied
Score: 100
Status: offline
Do you think the 60 size Dubro Tailwheel bracket is really necessary? I'm thinking of using the 40 size Dubro Tail Bracket. I always fly off of grass.
Hide Signatures
(in reply to Tom Nied)
       Post #: 48
RE: Cap 232 Profile ARF - 10/22/2010 6:11 AM
F4U Corsair
Score: 125
Last Login: 5/8/2013
Status: offline
Tom, your asking questions on a 5+ yr. old thread. I doubt those who post still have them. These usually only last a season or two at best due to trying crazy ass 3D manuvers down low. A few guys at our club fly these and if your flying off grass the tail wire is plenty good. These profiles take about 5' to lift off due to the hugh wing area and overall weight. The CAP is quite tail heavy if I remember right, the landing gear is weak, but bends back easily, the covering sucks, but for the money these will definately put a smile on your face. The one I flew hovered best leaning on it's back a bit and did a great inverted flat spin, must be the aft CG. I fly the Butterfly 3D and it is even more floaty, but not quite as wild as the CAP can be with throws set at 45 degrees or more. I hated the Katana version, way too heavy and built way too weak. A few threads down there is another thread on the BF3D and I believe lejongleur
just got one of the CAPs (he powers with electrons) so you might want to read those threads as well. Enjoy!
Experience is something you aquire after you need it!
Hide Signatures
       Post #: 49
RE: Cap 232 Profile ARF - 10/22/2010 6:23 AM
Tom Nied
Score: 100
Status: offline
Yeah, will check it out. Thanks. Never had a profile so I'm low on the learning curve.
Hide Signatures
(in reply to F4U Corsair)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.233RCU1
