RE: OFFICAL TIPS AND TRICKS THREAD
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: OFFICAL TIPS AND TRICKS THREAD
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: OFFICAL TIPS AND TRICKS THREAD - 3/9/2005 2:14:50 AM
Skullbasher
Status: offline
Well, like computer paper is about right. Although not required...
_____________________________
"You can't catch a Nitro with an Electric, you catch a Nitro with a Nitro"
(in reply to brownstone101)
       Post #: 26
RE: OFFICAL TIPS AND TRICKS THREAD - 3/9/2005 3:00:56 AM
brownstone101
Status: offline
k when i get my sper geare
TA-05 - Trinity P2K2 27T, Novak Cyclone TC, JR XR3
Nitro Evader ST rebuild project.
(in reply to Skullbasher)
       Post #: 27
RE: OFFICAL TIPS AND TRICKS THREAD - 3/9/2005 5:26:36 AM
mittimj
Status: offline
to keep your body from smacking doun on the mounts when you land off a jump put little pices of fule line between the mount and the body.
If you find yourself always running out of the plastic shock spacers use Zip Ties in place of the spacer.
When watterprofing servos with a baloon, the hole you put in it for the servo horn to attach, put a little dob of greese on there to keep watter form entering. And some greese where the wires come out too is nice.
If you keep breaking a particuliar part on your vechile ex: a spindle, take one off a similar car but diffrent make and costomize it to work. Hey I got xxx-nt hub carriers and hubs/spindles on my traxxas rustler.
When a part breaks out in the field it can usually be fixed with CA, mechanics wire/paper clips, or rubber bands. I mean I broke the top part of a shock cap and held it back on with rubber bands and it worked mint.
       Post #: 28
RE: OFFICAL TIPS AND TRICKS THREAD - 3/9/2005 5:43:10 AM
Skullbasher
Status: offline
quote:
ORIGINAL: mittimj
Speaking of... I have a gt front end for a while... worked pretty well I might add.
(in reply to mittimj)
       Post #: 29
RE: OFFICAL TIPS AND TRICKS THREAD - 3/9/2005 6:01:11 PM
walkerNCST
Status: offline
Fuel tank o-ring tip: (I know it works on my NEST, but I don't know about other fuel tanks)
The other day the o-ring was not sealing properly on my tank. Instead of replacing the o-ring... try to tighten down the screw on the underside of the cap. This will compress the o-ring and cause it to increase the width of the o-ring... which in turn tightens the fit. I tightened my screw 2 full turns over 2 months ago and my tank hasn't spilled any fuel out of the top and it has maintained the proper seal ever since.
Nitro Evader ST, Mini-T,
T-Maxx w/ OS .15 cv-x hyper
       Post #: 30
RE: OFFICAL TIPS AND TRICKS THREAD - 3/9/2005 6:14:39 PM
be4life182
Status: offline
After trying to start your NEST(or any other), and then realizing it wasnt even primed(blue fuel line,argg), always make sure you take off the glow plug starter before putting your finger over the exhaust and yanking to prime it. Just trust me on that one.
(in reply to walkerNCST)
       Post #: 31
RE: OFFICAL TIPS AND TRICKS THREAD - 3/9/2005 11:47:08 PM
brownstone101
Status: offline
lol hot fuel feel bad for ya i take it off because i dont like wasting battiries
(in reply to be4life182)
       Post #: 32
RE: OFFICAL TIPS AND TRICKS THREAD - 3/10/2005 4:04:06 PM
Black_Ghost_FN
Status: offline
I havwe an X-C and Sometimes its anoying to put the body on because of the excess wire sticking out because it bends. What Im gonna do is fold that excess wire downward and then shrink some shrinkwrap over it and the wire cover.
       Post #: 33
RE: OFFICAL TIPS AND TRICKS THREAD - 3/10/2005 10:34:20 PM
peggerbuilt
Status: offline
How many anntena tubes have you all broken? Try this: right where the tube(or slighty below) exits the body, cut it(the tube, not the wire). Then take about one and one quarter inch of fuel line and slide it over the two sections of the tube to hold it together. When you car rolls, the fuel line will do all of the bending thus saving the anntena tube.
it ain't broke 'til the fat lady steps on it
(in reply to Black_Ghost_FN)
       Post #: 34
RE: OFFICAL TIPS AND TRICKS THREAD - 3/11/2005 3:00:45 AM
brownstone101
Status: offline
that sounds good i would do swrink rap it holds better
(in reply to peggerbuilt)
       Post #: 35
RE: OFFICAL TIPS AND TRICKS THREAD - 3/11/2005 5:20:58 AM
peggerbuilt
Status: offline
yes thats not bad shrink wrap would hold better but not as tough as fuel line. Maybe some shrink wrap on the end of the fuel line. HHHMMMMMMMMMM???????????????
       Post #: 36
RE: OFFICAL TIPS AND TRICKS THREAD - 3/12/2005 12:45:56 AM
brownstone101
Status: offline
it would melt maby???? i dont know my hose holds good
       Post #: 37
RE: OFFICAL TIPS AND TRICKS THREAD - 3/12/2005 5:17:35 AM
Black_Ghost_FN
Status: offline
I put shrink wrap on it, it is thik and will never brake. and the shrink wrap also goes over the little part of the reciever box that sticks out.
       Post #: 38
RE: OFFICAL TIPS AND TRICKS THREAD - 3/12/2005 5:31:01 AM
brownstone101
Status: offline
ok this is a good one shock boots take a water balloon cut a small hole on the bottom and cut the top rim off then take spring off slip it over the shock body and bottom part the cut a small needle size hole on side so air can move put back together and you have a good shock boot i will get pic
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by brownstone101 -- 3/12/2005 5:37:32 AM >
       Post #: 39
RE: OFFICAL TIPS AND TRICKS THREAD - 3/12/2005 5:37:55 AM
