?? belt drive tail rotor ??
Tower Hobbies
Logged in as Guest
  Printable Version
Align T-Rex 450SE - ARF
Seller:  seaview
Details:   $845.00   |  11/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> ?? belt drive tail rotor ??
Page: [1]
Login
?? belt drive tail rotor ?? - 3/5/2005 4:30:09 AM
bluealien
Status: offline
I'm curious, what are the advantages of a belt drive tail rotor over your conventional gear driver rotor????
       Post #: 1
RE: ?? belt drive tail rotor ?? - 3/5/2005 8:36:42 AM
chronus
Status: offline
I would say belt because inline with the gears would be more efficient(vs drag of belt) as opposed to 90 degree meshing with pinions on shaft drive, so take away the drag of the belt vs the 90 degree crossovers you may end up the same as far as efficiency is concerned but i would think the belt less likely to strip the gears .
The new ikarus hel "viper" has an interesting belt drive system http://www.ikarus-modellbau.de/onlineshop/deutsch/index.php?lang=1
< Message edited by chronus -- 3/5/2005 10:17:57 AM >
(in reply to bluealien)
       Post #: 2
RE: ?? belt drive tail rotor ?? - 3/5/2005 9:45:10 AM
acr1346
Status: offline
Less drive flex, sometimes called windup. Gear mesh drag from incorrect gear settings. stripping gears, broken
drive wire or carbon shaft in crash just to name a few.
_____________________________
You can fly the Empire State Building if the motor is big enough!
(in reply to chronus)
       Post #: 3
RE: ?? belt drive tail rotor ?? - 3/5/2005 2:29:27 PM
bigbri
Status: online
A big disadvantage of belts is that they take a LOT of power to spin. I believe close to a 18% power loss turning the belt.....Big advantage ease of set up and crash costs. The belt is rarely ruined in a crash unlike a tube drive. With the power of todays engines the power loss to drive the belt is not that big as issue.
(in reply to acr1346)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.282RCU2
