Good Glider Transmitters
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> Good Glider Transmitters
Page: [1]
Login
Good Glider Transmitters - 3/5/2005 6:00:23 PM
samolot
Status: offline
Im just thinking about the possible good transmitters available for gliders. Can someone tell me what are some good ones for scale soaring? Must be computer and <250.
       Post #: 1
RE: Good Glider Transmitters - 3/5/2005 9:47:51 PM
ejett
Status: offline
Probably the best bet is to look for a used Futaba 9CAP (or F), a used JR 8103, a used Airtronics Vision VS8SP (hard to find) or possibly a Stylus (hard to find under $250). The new Futaba 9CAP Super would be better, but it will not be obtainable new for under $250. Note that there is a Vision VS8P that is for power planes and is not very good for sailplanes. It is generally easier to find and less expensive. There is an upgrade for the Vision, but upgrading the VS8P to the version 3 sailplane software is about $150 worth of additional expense. This upgrade can still be done. In general, all of the radios listed above are still supported except the Vision so I would put it at the bottom of the list.
Watch the RCU Marketplace and RC Groups for sale/WTB forums.
EJ
< Message edited by ejett -- 3/5/2005 9:51:54 PM >
(in reply to samolot)
       Post #: 2
RE: Good Glider Transmitters - 3/5/2005 10:12:38 PM
ejett
Status: offline
Here is a current ad in RCU for a Vision with the 3.0 Sailplane upgrade.
http://www.rcuniverse.com/market/item.cfm?itemId=81457
An RCU ad for JR 8103 DT - http://www.rcuniverse.com/market/item.cfm?itemId=81492
There are other possibilities there too including a Futaba 8UAFS that could work, but I didn't put in my other list.
All of these deals are for Tx only (generally include charger) but no Rx or servos.
EJ
(in reply to ejett)
       Post #: 3
RE: Good Glider Transmitters - 3/5/2005 11:52:56 PM
TFLG
Status: offline
If you want a Tx that will work full house glider (retract, spoilers, tow release, flaps ailerons, ruder and elevator) you will need a high end one. The Futaba 9C the Stylus, the 9303 etc. You will not get any of these for under 250 unless you get a used one. Your best bet for used ones under 250 is the Stylus. I see them on Ebay and RCgroups occasionally for under $250. If fact I just sold a Stylus for $250. The 8UAF will sorta work but without the sliders on the side of the radio you end up with spoilers on a switch (some guys prefer this though)
TFLG
< Message edited by TFLG -- 3/5/2005 11:54:52 PM >
(in reply to ejett)
       Post #: 4
RE: Good Glider Transmitters - 3/6/2005 2:31:39 AM
John C
Status: offline
Hitec Eclipse 7 channel will handle a 4 servo wing and provide crow - ask me how I know There is a Tx only for sale now for $175 - that's a bit high I tink, but shows you can get full house for under $250.
John C
(in reply to TFLG)
       Post #: 5
RE: Good Glider Transmitters - 3/6/2005 3:21:35 AM
PaulBK
Status: offline
I would look at a used 8103. My preference for a scale ship was to use the power software, rather than the glider stuff, which was better suited for TD ships. if you have flaps and retracts you may have to combine channels.
P
(in reply to John C)
       Post #: 6
RE: Good Glider Transmitters - 3/14/2005 3:07:50 AM
aeajr
Status: offline
Which radio for scale gliders? Others will tell you what to buy. I am
going to try and explore some key features and channel uses to help you
understand what to look for and why. I will mention some radios at the end.
This is not a simple topic, so grab a cup, this will take a little while.
During this discussion I am going to use Hitec/Futaba channel assignments as
the examples. Since I have a Hitec Prism 7X and a Futaba 9C, I know these
layouts best. I will also assume you know something about computer radios and
the use of surface mixes, so I am not going to explain every mix I might want
to use on a full house or scale sailplane.
If you are not familiar with computer radios, this article might be helpful.
Radio Systems Part 2 - Computer Radios -
http://www.rcezine.com/cms/article.php?cat=&id=65
I am going to focus on how many channels you will need and some very valuable
features to look for in a radio.
Most scale gliders will have ailerons, rudder and elevator. Most have a tow
line release for aerotowing. Most will also have either spoilers or flaps,
and some have both. Some also have landing gear. So what you need depends on
what plane you are flying.
At a minimum, scale planes would need at least 5 channels to account for the
tow hook.
Surface/ channel # (futaba/hitec typical layout)
A = 1
E = 2
F/S = 3
R = 4
TR = 5
That means a Hitec Laser 6 standard radio could fly this plane but would not
offer us any channel mixing. I don't recommend standard radios for full house
or scale sailplanes.
In practice, we typically use two channels for ailerons and flaps so we have
one servo/channel per surface. To do this we are going to need a computer
radio to mix the split channels together, to have the servos work together.
When deployed this way, this is commonly refered to as the 4 servo wing. The
ability to control 4 servos independantly is a significant breakpoint in the
computer radio market. There are those that can do it and those that can't.
While we could use either, if we are going to bring the plane to its full
potential, we will want a computer radio that can manage a 4 servo wing, each
on its own channel.
First, this makes it easy to trim the surfaces from the radio. It also allows
us to change how a surface is used during the flight.
For example, if both flaps are on one channel via a Y cable, then we can move
them up and down together. However if they are on two channels, we can flip a
switch and have them follow the ailerons to improve roll response. This
video illustrates this arrangement as quad ailerons:
http://airfieldmodels.com/video/quad_ailerons.wmv
Here the flaps follow but at about 50% of the ailerons:
http://airfieldmodels.com/video/flaps.wmv
If we have ailerons on separate channels, we can have the up aileron go up
more than the down aileron. This is called differential ailerons and helps
reduce drag.
The 4 servo wing allows us to do camber control. This will allow us to
change the shape of the wing by moving the whole trailing edge as a unit. It
changes the flight characteristics of the wing so we can tune it to different
situaitons during the flight. If the ailerons are on one channel, we can't do
that.
This video shows a variety of movements, two of which illustrate a small
movement up and down together to change the entire trailing edge:
http://airfieldmodels.com/video/quad_flaps.wmv
Crow and Butterfly, are also in common use. In this mix, flaps go down and
the ailerons come up to really slow the plane quickly. Normally the elevator
is mixed in to help keep the plane level. This video illustrates crow.
http://airfieldmodels.com/video/butterfly.wmv
Likewise when winch launching your sailplane you will probably want a launch
set-up. This typically involves dopping the flaps about 30 degrees and the
ailerons about 15 degrees. This helps maximize lift during the launch. If both
ailerons are on one channel, you can't drop them together. Best to have them
on two channels.
So the message is that there is big value in having a 4 channel/4 servo wing.
Here is a sample layout using the Futaba 9C recommended channel assignments.
Surface / Channel
R Aileron 1
Elevator 2
throttle stick 3 ( used to contol other functions or a launch motor)
Rudder 4
R Flap 5
L Flap 6
L Aileron 7
Tow rel. 8
That would be 7 channels. However, many radios tie channel 3 to the throttle
stick. It is common to use the throttle stick to control the landing mixes I
illustrated above, so we may lose the use of channel 3. If that is the case,
we will need 8 channels.
If your radio will allow you to move channel 3 control to a switch to work the
tow release, or perhaps a motor, then we can get away with 7 channels. If you are looking at a 7
channel radio, look for the
ability to assign this channel to a switch AND support for the 4 servo wing.
However I am going to play it safe and assume we need 8 for the rest of the
illustration.
Would we ever have use for more than 8 channels? Of course! There is always
more stuff we can put on a plane.
We will use my Ventus 2C as an example. I have the plane laid out as shown
above on 8 channels However my wings also have spoilers, though I don't have
them set-up right now. While I could put each spoiler on a separate channel
and create a 6 servo wing there is no real need for this and my radio doesn't
support it. I would put both spoilers on one channel. That takes me to 9
channels.
I could also add landing gear and use the 9th channel for that. If I wanted
the spoilers AND landing gear, I would need 10 channels in my current set-up.
If I didn't have 10 channels, I could put the flaps on one channel to free up
a channel to accomodate both the spoilers and landing gear. That would work,
but I would lose flexability on how I trim and control the plane, as described
above.
So, you can "make things work" depending on the features of the radio and your
willingness to give up some flexability.
I have a Futaba 9C which will give me what I need to manage the Ventus 2C. It
has a maximum of 9 channels so I would have to work within that constraint. I
am not sure if I can move channel 3 to a swich. I never looked because I have
enough channels for my current set-up without this feature.
Can I fly it with a less flexible radio? Sure!
A Futaba 7C, could fly my Ventus but it does not support 4 servo wings, so I
would give up some flexibilty.
A Futaba 6EXA or a Hitec Flash 5SX could fly it if I put the flaps together on
one channel and the ailerons together on one channel.
Standard radios, like the Hitec Laser 6, could fly it, however don't buy a
standard radio to fly full house or scale sailplanes. If you have one and
have to make do, that's fine but it would be a mistake to buy one for this
kind of plane.
We can look at the Futaba 9C Super, which appears to have replaced the 9C at
$290, as an entry level radio for this environment.
http://www.servocity.com/html/9ca_super_systems.html
http://www.futaba-rc.com/radios/futk75.html
The super can do more than the original 9C, so it may be all you will ever need.
However there are many radios that could handle theese requiremts. Perhaps
there are some at lower cost, but I am not aware of them.
Some examples of more expensive radios to look at would be the Airtronics
Stylus, Multiplex Royal Evo 9, the JR 9303 and and a bunch of others. These
all run in excess of $400 and some a lot more. And these are no where near
the top on the price chart. There are radios that run over $2000 with 14
channels. If you got the $$, enjoy!
So, many radios can fly a full house sailplane and many can fly a full house
scale sailplane, but if you want to really bring the plane to its full
potential, you are going to need a computer radio that, at a minimum, has full
support for a four servo wing and probably has at least 8 channels.
PS: Read this only if you like to dabble in deeper technical stuff. This
article is on advanced set-up of a full house sailplane. Definately not
something a beginner, or even a many experienced ailplane pilots need to do.
This is more for competition pilots, but if you like to look at some of the
advanced stuff, this might be fun. It is a translation, so take your time as
you read it.
http://www.gliders.dk/triming_and_setup_of_a_glider_wi_eng.htm
< Message edited by aeajr -- 3/20/2005 10:19:36 AM >
_____________________________
Clear Skies and Safe Flying!
Ed Anderson
Moderator
Park Pilot Program Partner
(in reply to PaulBK)
       Post #: 7
RE: Good Glider Transmitters - 3/14/2005 4:09:15 PM
aeajr
Status: offline
quote:
ORIGINAL: John C
John C
John C,
I presume you have seen the post above this one. I do not include the Eclipse 7 among the radios that I feel meet the needs to set up a scale plane in the optimal fashion, but perhaps you can enlighten me. You seem to know this radio pretty well. Can you make this set-up, or something similar, work on th Eclipse?
R Aileron 1
Elevator 2
Tow release - 3 (assigned to a switch)
throttle stick ( used to contol landing mixes)
Rudder 4
R Flap 5
L Flap 6
L Aileron 7
It seem that, for the Eclipse to handle the 4 servo wing and have enough channels to handle the tow release you need to use channel 3, yet leave the stick open for flaps/crow control.
Do you know how to do this? If so, how can I take channel 3 off the throttle stick and assign channel 3 to a switch to operate the tow release? We have enough channels, if we can move 3 to a switch.
Also, I spent a lot of time researching radios before my purchase of the 9C. I did not think the Eclipse could provide the control that I needed. You said you can provide Crow off the Eclipse. How do you do that? You say it can, so maybe you know how to do this.
Maybe I should add the Eclipse 7 to the above post.
Thanks!
< Message edited by aeajr -- 3/14/2005 5:01:12 PM >
Ed Anderson
Moderator
       Post #: 8
RE: Good Glider Transmitters - 3/14/2005 5:48:58 PM
John C
Status: offline
Well....the short answer is no
Actually, when I answered, I wasn't thinking of all of the functions you are considering to the sailplane. For my Eclipse, set up for a four servo wing, I do use the throttle channel to control crow, per the Hitec manual.
1 - Right Aileron
2 - Elevator
3 - Crow/butterfly
4 - Rudder
5 - Left Aileron
6 - Right Flap
7 - Left Flap
I do think my next radio will be an EVO 9 to get a full compliment of alternatives to work with although I really like the Hitec SUper Slim 8 channel Rx in my sailplanes.
John C
(in reply to aeajr)
       Post #: 9
RE: Good Glider Transmitters - 3/14/2005 5:58:13 PM
aeajr
Status: offline
Thanks John C,
I agree that is a good full house set-up, especially if it can manage crow, but we need the tow hook release for aerotowing scale planes. If we are winching them, then it is no problem.
I have heard of people attaching the tow release mechanism to the rudder servo. When the rudder servo goes all the way over to one side, it releases the tow line. Not something I would want to plan for if I was choosing a new radio, but if you have one, like the Eclipse, and need to operate the release line, this could be a way to get it done and still be set up for a 4 servo wing.
You could fly up with rudder on low rate so it can't move far enough to release the line. Then flip to high rate and blip the rudder hard over for a moment to release. Could work!
Just a thought
Ed Anderson
Moderator
       Post #: 10
RE: Good Glider Transmitters - 3/14/2005 7:56:27 PM
aeajr
Status: offline
quote:
ORIGINAL: John C
1 - Right Aileron
2 - Elevator
3 - Crow/butterfly
4 - Rudder
5 - Left Aileron
6 - Right Flap
7 - Left Flap
John C
John, you might find this interesting. I just got a reply back from the Hitec support folks.
http://www.rcuniverse.com/forum/Eclipse_7_%2D_moving_channel_3_assignment/m_2763572/tm.htm
Here is what they said:
On the Eclipse the assignments will be as follows:
channel 1- right aileron
chennel 2- elevator
channel 3- tow release (controlled by elevator D/R switch)
channel 4- rudder
channel 5- left aileron
channel 6- right flap
channel 7- left flap
(channels 6 and 7 are controlled by what would normally be the throttle stick for landing or crow function on a glider)
Interesting? Did we just learn something new about your radio that could be useful to you?
They said it is documented on page 8 of the glider section. If you try it, let me know if it works. If it does, then I can point to the Eclipse as the lowest cost radio I have discovered that can handle the 4 servo wings AND handle a tow release on a scale glider. Up until now, it was the Futaba 9C. $100 price difference here.
While the 9C definately brings some extra value, for the pilot on a tight budget, the Eclipse could be a good solution.
< Message edited by aeajr -- 3/14/2005 8:45:02 PM >
Ed Anderson
Moderator
       Post #: 11
RE: Good Glider Transmitters - 3/18/2005 3:44:55 AM
kestrel53065
Status: offline
aeajr/John C,
It appears to me that your assumptions are correct. I have an Eclipse 7 set up as you have listed. Chanel 3 is open on my 8 chanel Rx. So, I plugged a servo into it and yes the Elv. dual rate switch activates it.
I have used this Tx with a couple of six servo models. It works fine and will do crow on the throttle stick including elv. compensa
