Clean
Joined: 4/19/2002 From: Parkville, MO, USA Status: offline
Use 14 pound test Fusion Syder Wire, this is the knit type wire, not monofilement and is available at Kmart and Walmart in the fishing section. Lighter, cheaper to replace than cable and less draggy than the white stuff. The engine in the Viper is the cause of your problems, it needs an upgrade. Take it off, take it apart and start working. First, reset the ball on the piston, mine was loose from the get go, tighten it up and you have more power. There is not supposed to be much difference in power between the two slit exhaust and the open exhaust, but if you have a cylinder that is open and has the two port feed, swap it. I've heard someone knows how to pop those slits open, but I can't see me doing it successfully. There is a post over on Stuka by Larry Fernandez http://www.clstunt.com/htdocs/dcforum/DCForumID1/13027.html and he has taken the backplate off the motor, modified it and JB welded it into the back of a Norvel engine, then mounted that sucker into the Viper. More power than you'll ever need that way. I have swapped out a Blackwidow base with TeeDee .051 piston/cyl assembly and bored the mount breather hole for better flow, it screams pretty good but now I get fuel foaming problems from the tank, will switch to a balloon tank to get rid of those problems. When it has power, the viper flies fairly well, but you have to work the engines over for it.
_____________________________
From Somewhere near Parkville, Mo. William Crane (aka Mr Clean) Rever Brother #168 Time Man of the Year
