RE: "Eliminator 2" sport jet final assembly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: "Eliminator 2" sport jet final assembly
Page: <<   < prev  1 2 [3]
Login
RE: "Eliminator 2" sport jet final assembly - 3/18/2005 1:29:44 PM
smchale
Status: offline
Good news on the engine!! I look forward to seeing some flight reports! Good luck!
_____________________________
Cheers, Sean McHale
www.strictlyscale.com....and Revver Brotherhood #101
(in reply to daven)
       Post #: 51
RE: "Eliminator 2" sport jet final assembly - 3/18/2005 8:33:24 PM
johntheroadie
Status: offline
Hey Mike;
Quick question, but have you incorporated a tail skid on the prototype to prevent prop strikes during take off and landing? Or is it there and I just don't see it in the pictures? I know that your design will allow quite a bit of rotation before the prop will strike, but I was just wondering if it was there or not...
I'm getting really excited to see it come this far! Best wishes for the maiden!
johntheroadie
Revver Brotherhood # 108
(in reply to Mike James)
       Post #: 52
RE: "Eliminator 2" sport jet final assembly - 3/18/2005 9:56:18 PM
Mike James
Status: offline
I haven't put a tail skid on the plane. I would leave that to the builder, depending on what they felt about it.
Since we haven't flown it yet, I don't know if it's a problem. We'll see...
Mike James
RC Design and Building - www.nextcraft.com
(in reply to johntheroadie)
       Post #: 53
RE: "Eliminator 2" sport jet final assembly - 3/18/2005 10:41:30 PM
CFII1974
Status: offline
Wow Mike I am Glad to see you getting so close. I have followed your progress while the threads have been moved around and I can't wait to read the flight report.
When you're ready to sell, sign me up. She is a sweet ship.
Dave
Also I am going to put a link in the jets forum to this thread, JIC some of the guys that used to follow this don't make it into the speed forum.
If you're not Flying you're not Trying!
       Post #: 54
RE: "Eliminator 2" sport jet final assembly - 3/18/2005 11:29:24 PM
erbroens
Status: online
Nice work Mike, like Johntheroadie said, I would suggest too install a wire at the tail to spare those pusher props...
Rgds, Enrique
< Message edited by erbroens -- 3/18/2005 11:34:43 PM >
E pluribus unum
(in reply to smchale)
       Post #: 55
RE: "Eliminator 2" sport jet final assembly - 3/19/2005 1:19:33 AM
Johng
Status: offline
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
Go Mike!
John
(in reply to erbroens)
       Post #: 56
RE: "Eliminator 2" sport jet final assembly - 3/19/2005 1:28:51 AM
Johng
Status: offline
Something for the future: Consider that you could convert this plane to turbine by adding former extensions thru the top skin to make a turbine pylon mount between the verticals a-la Kangaroo. Keep things simple at first. Leaves lots of space inside for easy set up of a fuel tank too. ..small steps....
As for the engine size, .61 would maybe do it. Does Master Airscrew make their 12x6 3-blade in a pusher version? That is a very good prop as far as effiecient 3-blades go. I hope there's a 12x8 or 12x9 3 blade for that 91. What prop have you got Mike?
You can always bring that bird down here and fly off a half mile of pavemant at my field Highs in the 70's, wind less than 5 mph this weekend. Road trip!
I got to PM ya Mike, quite a bit has happened since we caught up.
John
(in reply to Johng)
       Post #: 57
RE: "Eliminator 2" sport jet final assembly - 3/19/2005 1:36:42 AM
Mike James
Status: offline
Howdy, John. Great to hear from you.
Good suggestions. With the .60 we'd use Zinger 12-6 and Zinger 12-8. With the .91 either of those would work too, but would be at higher RPM's. Turbine version is a way off, but I do appreciate the suggestion. Simple is good!
I look forward to your email or PM.
Mike James
(in reply to Johng)
       Post #: 58
RE: "Eliminator 2" sport jet final assembly - 3/19/2005 2:21:28 AM
johntheroadie
Status: offline
Hey Mike, I re-read my post and wanted to tell you that I'm not trying to tell you how to build your plane, I just was curious if you had taken it into consideration. If everything goes well (like we all hope!), I'd like to see it as an option for the builder. Also, thinking ahead if you make a turbine conversion, a tail skid will be redundant. So I like your idea of letting the builder add it on, provided it's a fairly easy job.
I don't think it would be hard anyway.... Just mount a length of piano wire in the motor mount and drill a small hole in the fuse and that would be all that's needed from ruining those hard-to-find pusher props...
johntheroadie
       Post #: 59
RE: "Eliminator 2" sport jet final assembly - 3/19/2005 2:27:28 AM
Mike James
Status: offline
Hey, no offense taken.
All of the design details and fabrication have been done by me alone. There are 10,000 items to do. So, it's always good to hear what you guys think... Who knows? Maybe I forgot #763, or whatever.
More than one brain is good. Thanks to everybody.
Mike James
       Post #: 60
RE: "Eliminator 2" sport jet final assembly - 3/26/2005 9:57:09 PM
Mike James
Status: offline
Hello everybody,
A little background is necessary, so you'll understand this announcement...
Until 2002, I was doing these model-related things, including my web site, as an independent designer and builder, and doing occasional outside projects. Since then, trying to do the modeling business full-time, I've had two very bad run-ins with "manufacturers" who not only harmed me financially, but in one case, actually stole most of my tools, and a couple of my plugs. One was in a foreign country, and was pretty dramatic.
During the last of those two experiences, I became friends with a person who very generously helped me survive. Later, we decided to give the manufacturing of these models a go, and have been working on that since August of 2004. I won't identify him here, to respect his privacy, and will leave it to him whether he wants to be involved in the public news about this. He funded the operation, and (since my tools were stolen) also offered the use of his shop, and a place to stay etc. I did all the model-related work and web site work. Keep in mind that I have lost money continuously on this for 3 1/2 years now, barely surviving, in the hopes that I could make it work.
You'll notice in the online article ( http://homepage.mac.com/mikejames/nextcraft_site/j47_sportjet01.html ) that we switched concepts part-way through the project, from the idea of a fiberglass fuselage with foam wings and tail parts, to a completely-molded, all-composite design. This made the project take longer than expected, and while it didn't raise our materials cost too much, the mandatory wait times for epoxy curing and vacuum bagging has increased the labor costs. Having now looked at the money spent to far, as well as our predictions on what we could sell the model for, and it's profit-per-kit, we find that we simply can't produce the kit at this time. We would have to sell the kit with foam parts for at least $600, and the "deluxe" all-molded kit would be close to $1000, to make any kind of profit, and we have assumed that this price was too high for the market we were aiming at. While there's been discussion of the development of a turbine version, which could be sold at competitive turbine prices, none of this work can happen until I repay the investment, since my partner is holding on to all the plugs and molds. He has spent a lot of money, and it's for his security, rightfully so. So, in lieu of continuing, I have moved back home to Anchorage. (My email addresses and web site will all remain active.)
My partner still intends to test-fly the prototype, but not until late May, just before the Joe Nall event. I hope he will have good results, and that he will get both still photos and video. Until I've paid back the investment on this airplane, he has ownership of the projects, to protect his investment. Let me be clear about what this means. This person is not "screwing me", and we are not "fighting". It's simply that with only one set of molds at this time, and the prohibitive labor costs, we cannot continue to spend money. That means that the "Eliminator 2" and the King Air ( http://homepage.mac.com/mikejames/nextcraft_site/b200_construction01.html ) are both on hold indefinitely. For your information, no one has placed an advance order, and no one has given us any deposits or other funding. We didn't quite make it to that stage, and wouldn't have accepted any outside money until we knew we could in fact produce a proper product. No prospective customers will lose money.
I've moved back home to Anchorage, in the hopes of raising the money to pay back the investment, after which I can once again explore some kind of production of these kits. I have to pay this debt before I can start to rebuild a shop and accumulate the tools, so recovery will take a while. I'll will do my best, but am basically starting over from scratch, and can't begin to predict a "back in action" timeframe yet. I will continue to post new articles on my web site, and to contribute on the online forums, but will be out of the physical fabrication of models for a while.
As more information becomes available, you can depend on it that I'll let you know. Be aware that there are a LOT of people following these projects, and that until I get settled here, my internet access is somewhat limited. So if it gets too difficult to keep up with the email, I may have to resort to automated responses. This announcement describes everything I know at this time. For now, all I can do is cover my immediate survival, and start making new plans. Watch the "Latest News" page for updates, too, but as I said, it will take a while. I know this is disappointing news to many of you, as it is to me. If you can bear with me during my recovery, I hope you'll all become happy customers at some point. Thank you for your interest and support so far, and please keep your fingers crossed for me.
Take care, everyone, and happy flying.
Mike James
       Post #: 61
RE: "Eliminator 2" sport jet final assembly - 3/26/2005 11:30:02 PM
kennyandannie
Status: offline
Mike,
I hope everything goes well for you, as I'm sure it will. You've come back from adversity before and you'll do it again.
Do what you need to do and let us know how you're doing from time to time. You have my e-mail address if you need it.
Take care and God Bless,
Ken
< Message edited by kennyandannie -- 3/27/2005 2:03:26 AM >
Ken Thompson - Team Black Magic - Team DragonFire
Fellowship of Christian Modelers
       Post #: 62
RE: "Eliminator 2" sport jet final assembly - 3/27/2005 1:07:21 AM
daven
Status: offline
I wish you the best Mike. I have enjoyed your threads, and helpfull hints. I am an extreme novice composite builder, and I have seen how difficult this really is to do successfully. I have also seen the costs involved, and can see why this project has turned cost prohibitive. It also shows why a basic box fuzed, constand chord, composite quickie 500 runs in the 500-600$ range.
Dave Norman
klasskote.com
supertrc.com
(in reply to kennyandannie)
       Post #: 63
RE: "Eliminator 2" sport jet final assembly - 3/27/2005 2:19:39 AM
