my urgent hitec concirn
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> my urgent hitec concirn
Page: [1]
Login
my urgent hitec concirn - 3/9/2005 5:52:28 PM
adrian-RCU
Status: offline
i must have more than 100 hitec servos - 300's/55/81/422/425/605/635/5645/5945 and 5955's - to this day and it's been around 6 years, eccept for a few gears and one or two lost in crashes - not a single problem.
now this seems funny as i have followed all the problems and issues to date - the 605's not centering/ mine does ok - the 5645 lock up bonansa/ mine works fine - the 5945 problem and i use y connectors with futaba/ mine is ok - the 5955 issue/ well all seems ok they are still new - yes i have a programmer and seem to know how to work it.
but of late i get very concirned because of so much negative talk going on - when there is smoke maybe a fire - so i please ask the powers to be at hitec to really get under all these problems that pop up all the time because it makes old friends like me very very nervous.
we have more than 30 planes including several giants and i surely would not like to lose one of my babies due to this kinda crap!!!!! please adress these matters urgently and come out and let us know what is going on.
best regards
a truly concirned hitec fan and loyal customer
Click to see fullsize image.
Click for fullsize
_____________________________
TEAM"SHALAT RACHOK" Israel
       Post #: 1
RE: my urgent hitec concirn - 3/9/2005 6:10:06 PM
famousdave
Status: offline
I wouldn't worry about it. 99% of it is overreaction. I have the same "luck" as you with Hitec gear, as does most everyone else I know.
Just fly and have fun.
DP
(in reply to adrian-RCU)
       Post #: 2
RE: my urgent hitec concirn - 3/10/2005 1:00:43 AM
Panzlflyer
Status: offline
Well tell me why then after years of using the 5945s ( About 20 of them) do 2 new ones not work on a Y now that they have changed the version . And they all work individually. Hardly overreaction!
(in reply to famousdave)
       Post #: 3
RE: my urgent hitec concirn - 3/10/2005 3:32:42 PM
Andy540T
Status: offline
I have experianced the same issues as AndyT. Hitec replaced a component in the v.104 servos and now Futaba PCM won't work on a Y. They do work on JR and also will work with signal amplification either through a matchbox or similar divice. I purchased the servos based on Hitec's reputation and the ability to program the servos only to find out that programing them would be a waste of time since I would need a matchbox to allow them to work "ganged" on the same surface.
Desertpig and Adrian,
If you were to remove one of your servos, you would find that the version is something prior to v.104.
(in reply to Panzlflyer)
       Post #: 4
RE: my urgent hitec concirn - 3/10/2005 5:12:21 PM
adrian-RCU
Status: offline
yup - all our servos is 103 eccept for the 5955's also the programmer is 103
Click for fullsize
(in reply to Andy540T)
       Post #: 5
RE: my urgent hitec concirn - 3/10/2005 6:54:33 PM
famousdave
Status: offline
I have 1.03 and 1.04 firmware. I fly JR though and have no issues whatsoever. I always use Y-harnesses on all my split rudders except those that take 2 per elevator half..
Must be that Futaba junk (just kidding! ) The Fut rx signal gain is just not as high as the JR, Airtronics, Hitec RX for whatever reason. I have heard this come up a lot lately.
We probably should move this discussion to the open forum as this is really a manufacturer support forum and we have gone way off track here.
DP
< Message edited by desertpig -- 3/10/2005 6:56:40 PM >
(in reply to AJF--2)
       Post #: 6
RE: my urgent hitec concirn - 3/14/2005 7:38:01 PM
Brendan Lugo
Status: offline
With Futaba PCM receivers you have to use a buffered extension or y harness because of the low signal line voltage their receivers have.
Hitec RCD
Multiplex USA
       Post #: 7
RE: my urgent hitec concirn - 3/14/2005 8:01:58 PM
Andy540T
Status: offline
Brendan,
You still are not answering the question.
The question we have is: Why did the older versions (v1.03 and prior) work with a standard Y harness, and the newer ones (v1.04) require the buffered Y harness in order to work. We all have been using these servos on Futaba PCM without an issue until recently. This can all be resolved by answering this simple question that only Hitec can answer.
(in reply to Brendan Lugo)
       Post #: 8
RE: my urgent hitec concirn - 3/16/2005 1:54:04 AM
mglavin
Status: offline
Guys,
Thus far Hitec Engineers have not shared the technical reason for the shortcomings of the new servos with Hitec USA staff, they may not have the answer themselves at this time, we simply do not know. The problem(s) are being looked into and in time we'll tell the tale. Once we have definitive information we'll share it with all. Speculating on the problem and or forcing a technical response to appease users is of little to no value IMO.
Some suggestions that may have credence are noted below. These are obvious possibilities, nothing more.
Implementation of a new and or different IC.
Sensitivity to supply voltage or electrical noise on same.
Sensitivity to electrical noise on the signal input line.
Sensitivity on the signal and or power return line.
Sensitivity to the signal line source impedance.
Electrical noise; conducted and shared that's generated by the servos.
< Message edited by mglavin -- 3/17/2005 1:32:10 AM >
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
       Post #: 9
RE: my urgent hitec concirn - 3/16/2005 12:17:14 PM
adrian-RCU
Status: offline
now see - thats all we need, just tell us and all is ok!!!
we get hammered all the time for standing by hitec so sometimes we need a little support too,,,,,right!!
(in reply to mglavin)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
