Radio Setup questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> TEAM RCU >> Team RCU - Don Szczur >> Radio Setup questions
Page: [1]
Login
Radio Setup questions - 3/9/2005 10:38:55 PM
JuanSG
Status: offline
Hello!
I have some questions about radio setups, that I would like you could help me. I'm building a CAmodel Extra 300L 31% ARC, and this is my first GIant Airplane. I'm going to compete in F3M (called IMAC in USA) which have known/unknown patterns and freestyle flight, so I would like to know how I should setup it.
I have some doubts:
how do you setup your Extra for a competition like TAS or Don Lowe Masters (with Known, Unkown and freestyle routines)? . Do you have one model memory for fly known and unknown patterns with your Extra, and another model memory for fly the Freestyle?
Thanks for all your help
and good flights!
< Message edited by JuanSG -- 3/9/2005 10:44:00 PM >
_____________________________
Juan Sánchez - www.acro3d.com
       Post #: 1
RE: Radio Setup questions - 3/10/2005 2:59:59 AM
Don Szczur
Status: offline
My set up is very simple. I use triple rates on my JR 10X. I use low rates for sequence flying, with high rate for snaps, spins and hammer heads; then I use the third rate for 3D flying. Use good control linkages (ball links) and aluminum "3D" arms (1 1/2 inch long).
Best of luck with your setup!
If you scan the 3D section of RCU, and search for FiberClassics Extra 330 40%, I have a complete writeup on my setup which may also be helpful.
Don
(in reply to JuanSG)
       Post #: 2
RE: Radio Setup questions - 3/10/2005 7:02:31 AM
JuanSG
Status: offline
Thank you very much, but I can't find the write up of your setup of the FiberClassics Extra.
(in reply to Don Szczur)
       Post #: 3
RE: Radio Setup questions - 3/10/2005 12:07:07 PM
Don Szczur
Status: offline
I will do some searching for the link.
       Post #: 4
RE: Radio Setup questions - 3/10/2005 1:17:52 PM
Don Szczur
Status: offline
Here is the link which contains infomation on expo, dual rates, setup that could provide you with some ideas.
http://www.rcuniverse.com/forum/m_128103/mpage_1/key_/tm.htm
       Post #: 5
RE: Radio Setup questions - 3/10/2005 2:14:23 PM
JuanSG
Status: offline
Thank you very much Don!
       Post #: 6
RE: Radio Setup questions - 3/12/2005 10:34:53 AM
JuanSG
Status: offline
Don, do you have the rates assigned to different switches of only one switch with three positions for sequence flying, a high rate for snaps, spins and hammer heads and the third rate for 3D flying?
       Post #: 7
RE: Radio Setup questions - 3/14/2005 2:30:16 AM
Don Szczur
Status: offline
Single switch. That way its easiest to just turn that switch from low, to medium to high.
I did actually have 4 rates set up at one point, low (normal flying) rate, high rate for snaps and spins, third rate for rolling circles and a fourth rate for 3D.
That is with the 10X. THe upper right switch.
Don
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU2
