RE: KMP B-25 CONSTRUCTION.
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: KMP B-25 CONSTRUCTION.
Page: <<   < prev  25 26 27 28 29 30 31 [32] 33 34   next >   >>
Login
RE: KMP B-25 CONSTRUCTION. - 9/4/2007 11:21:45 PM
starberfarbin
Status: offline
LearnedINUK
I used the KMP cockpit kit.... modified several things to accomodate my batt(fuel tank!)
If you check the following posts in this forum there a pics and details......
#679 - Description of systems
#685 - Bombbay
#690 - Bombs and drop mechinism
#691 - Rotating Turret etc
#692 - Cockpit (notice the back wall is modified to allow for my battery below the turret mechanics
#693 - Tail gunner (not fininshed in this pic) and Retract stuff
#694 - electronics and bussiness part of fusalage
Also in referance to your lights..... I used RAM lights and modified them all! I also installed a switch to turn on the landing
lights when the gear comes down (for realism). I didn't put all my lights in the scale positions. Some B25's had them in different
locations than others I found. If u use the basic RAM nav light kit then modify it to suit your needs. RAM has alot of choices out there, just get a couple and start hacking! lol. I screwed up and put on a strobe (which didn't exist at the time!) but it sure looks COOL! lmao
Good luck
Hope this helps!
Stu
< Message edited by starberfarbin -- 9/4/2007 11:28:55 PM >
_____________________________
"FAA licensed Controller and LOOSE WING pilot, but you always walk away from a bad RC day!"
(in reply to LearnedInUk)
       Post #: 776
RE: KMP B-25 CONSTRUCTION. - 9/5/2007 1:57:11 AM
LearnedInUk
Status: offline
Great,
Thanks for the info. I will check out your posts.
(in reply to starberfarbin)
       Post #: 777
RE: KMP B-25 CONSTRUCTION. - 9/14/2007 1:29:16 PM
Eldher
Status: offline
As info on KMP's new B-25 may be of interest to this thread, below is a link to my original post.
KMP B-25 - New News?
       Post #: 778
RE: KMP B-25 CONSTRUCTION. - 9/15/2007 5:19:52 AM
kahloq
Status: offline
quote:
ORIGINAL: Eldher
96" wingspan is certianly nice and would be a real crowd draw. The problam in one respect is, that at that size, it cant do scale fly overs in formation and do bombing runs with the TF, H9 and current KMP 80-88" size planes and look right. It would be like a big elephant flying next to a few smaller sized animals.
This is part of the reason I nixed the idea of getting the H9 B-25 since the size was 8" smaller then the TF one. Next to eachother, the TF would dwarf the H9. Thus, I acquired a current version KMP 85" one.
(in reply to Eldher)
       Post #: 779
RE: KMP B-25 CONSTRUCTION. - 9/15/2007 9:38:14 PM
Bundy
Status: offline
Anyone like to guess what this new KMP 96" B-25 might weigh? A base Ziroli 101" B-25 built traditionally from balsa and ply can be done around 30lb, less if iron-on is used up to around 36lb decked out in a detailed glass finished with gear doors, lights etc and even up to 42lb for an early electric version.
Does an all composite construction offer a possible weight saving as well as a hard wearing, scaled detailed surface?
Richard
(in reply to kahloq)
       Post #: 780
RE: KMP B-25 CONSTRUCTION. - 9/17/2007 6:10:52 PM
Eldher
Status: offline
Reposting Original Content as this was pulled from the TF B-25 list.
I haven’t been following this thread, but have been in the market for a large B-25. This may be new news to you all or not. It was to me and based on advice of my friend, I’m sharing it with you all.
Understanding that KMP was reworking their B-25, I decided to contact them to find out what I could about it. Calling KMP (here in the US) directly yielded some, but not much. So, I called YT International in the UK and had a good discussion with a guy about what’s coming. Here are the basics of what I learned about the new KMP B-25:
- Wing span will be 96”
- Designed for twin 90 4cycle engines
- Lots of scale detail! A few tid bits he offered
--> pinned, scale, hinges
--> new scale retracts
--> choice of model. You can get the glass nose OR the hardened nose like the B-25H
They choose to make the B-25 larger for 2 reasons.
First, they don’t want the new B-25 to be directly compared with the H9 and Top Flight 25’s. His perspective is that many buyers do evaluation based on wing span and price. They are designing a high quality, very scale, B-25 to target the discerning scale flyer who will appreciate the plane.
Second, he said that larger planes, in general, fly better. Clearly, there are lots of factors that go into good flying, but for a given design, as you increase size you typically improve flying characteristics.
I didn’t ask about price. Given exchange rates and the fact that they are just a step in the chain before the kits come to the US, seems unlikely to get a meaningful number. HOWEVER, I did ask the US KMP sales rep what he expected the price of the new B-25 to be. He said that it’d be in the $1000 range. I interpret that to be in the range $1000 - $1500 (including retracts).
New B-25 will be available in the US in Nov or December.
Well now you now all I do on the KMP B-25. Hope this was useful.
(in reply to Bundy)
       Post #: 781
RE: KMP B-25 CONSTRUCTION. - 10/8/2007 10:44:29 PM
paulemv
Status: offline
Hi Guys, Did I tell you that mine FLYS like a DREAM!!!! The maiden flight went VERY well!!!! It must have make MR. Doolittle smile,I sure was.
On a almost PERFECT day, Wind, light and just off center of the runway, about 11:00 am. @ the Sundowners Field, Wheeler,In.
I have the whole 5 plus mins. flight memorise and it was a thing a sheer beautie, Iwill take that memory to my grave, not to soon I hope!
Can you tell that I am VERY well pleased with the whole process, Hope you all get the chance to do the same!
Paul T. VanDenburgh
(in reply to Bundy)
       Post #: 782
RE: KMP B-25 CONSTRUCTION. - 10/8/2007 10:59:24 PM
paulemv
Status: offline
HI GUYS, I just wanted to tell all of you that mine FLYS like a DREAM! Everything went GREAT, So THANK YOU ALL for the good advice.
On a prefect day, about 11:00 am. wind lite, and just a little off center, she rolled out just like a real one ,the take off was just beautiful...
Mr.Doolittle must have a smile on his face, There sure was a big one on mine! The Twins playing a beautiful note, the sweet sent of NITRO, OH what a wonderful thing to see...
So again I say, THANK to ALL, I hope you all have a chance to do the same....
Paul T. VanDenburgh
(in reply to Bundy)
       Post #: 783
RE: KMP B-25 CONSTRUCTION. - 10/8/2007 11:54:01 PM
LearnedInUk
Status: offline
Great, Glad to hear it.
With any luck mine will be ready for first flight this weekend. Still breaking in the engines.
Do you use on board glow? and what size engines?
(in reply to paulemv)
       Post #: 784
RE: KMP B-25 CONSTRUCTION. - 10/9/2007 12:55:58 AM
damagedgoodes
Status: offline
After so long or sitting on the shelf, mine should be ready in about a month also (it's the first generation with the main gear wheels facing inboard to each other) and wondered if anyone used the original stock 8.5 oz tanks and how long they usaully got from them (i'm running OS70FS). Cheers,
Dave
       Post #: 785
RE: KMP B-25 CONSTRUCTION. - 10/9/2007 3:54:45 AM
n9331v
Status: offline
I use the stock tanks and fly for 10 min then land and still have fuel left over. I am now running two RVC 90's.
This is one great flying twin.
Mooney N9331V
(in reply to damagedgoodes)
       Post #: 786
RE: KMP B-25 CONSTRUCTION. - 10/9/2007 4:44:43 AM
damagedgoodes
Status: offline
Thanks n9931v,
I intended to run it on the ground and time it for full throttle duration, but was debating pulling the tanks out and fitting larger before the first flight. I'll see if it survives the maiden before getting too excited...
(in reply to n9331v)
       Post #: 787
RE: KMP B-25 CONSTRUCTION. - 10/9/2007 4:47:58 AM
warks62
Status: offline
I would change the tanks if it was me. A good one that fits and what I used finally was this one. Very little mod needed. It gives the measurements so check it out. It is 14oz.
http://www.hobby-lobby.com/fueltank.htm
Randy
Click to see fullsize image.
Click for fullsize
< Message edited by warks62 -- 10/9/2007 4:48:49 AM >
Randy, member of the true 1/6th Royal Corsair Build
       Post #: 788
RE: KMP B-25 CONSTRUCTION. - 10/9/2007 11:36:02 PM
krproton
Status: offline
quote:
ORIGINAL: damagedgoodes
Dave
In my plane, the O.S. .70's consumed about 7 oz. after flying for about 12 minutes--that's "scale-like" flight on a warbird (partial throttle settings, some full throttle, some low throttle, etc.).
Tim Lampe
Hobbico R&D
       Post #: 789
RE: KMP B-25 CONSTRUCTION. - 10/25/2007 8:17:29 PM
