Idigbo
Joined: 2/1/2004 From: Stafford, UNITED KINGDOM Status: offline
Sam, the belly pan on my Mitchell is held on with two Hatch Catches, one at the front and another at the back, both on the centreline of the fuselage. They are both fixed into the belly pan, and slide forwards and backwards to locate into the fuselage at front and rear. Beauty of doing it this way is that it goes back onto the fuselage even when the wing aint on, and takes 2 seconds and no tools to fit or remove. Handy on mine as the reciever is mounted onto the bottom of the wing, so all wiring is accessible with the model assembled. I'll take a pic of the set up if I have explained it badly, but it is worth doing as trying to screw the belly on without breaking guns off the front, rear, top and sides is fun to watch (if not to do) to say the least!!!! Ian.
