samparfitt
Joined: 9/1/2002 From: West Chester, OH, USA Status: offline
Engine set up. I'm using OS FX .91's with MAS 14X7 3-blade props and OS A-3 glow plugs with Wildcat premium 5% nitro, 16% oil, and the engines are inverted. To get my engines to idle without overloading, I had to turn the low end needle 3/4 to 1 full turn in (lean, clockwise). On OS 2 strokes mounted inverted, looking in the carb with the throttle fully opened, there should be about a 1/16" gap between the needle and the fuel inlet tube. They can now idle for a minute and then go to full thottle without hesitation or stopping. If yours doesn't do that then keep leaning the low end a 1/16 - 1/8 lean until they do. The manual says 2 - 2 1/2 turns open for the high end. Inverted, they need to be opened more (lower on the low end but higher on the high end). I start at 3 3/4 open. After starting, the needle then needs to be leaned (clockwise) about 1/4 - 1/2 turn to get max RPM's. I forgot to put my readings down but I believe the RPM's was about 8000 for the 3-blade prop. There was plenty of pull with these two .91's so I'm rarely going to need to ever use full throttle. Remember to do the vertical test in the pit as well as just before taking off. Once you know they won't quite after idling, you should be able to eliminate testing just before taking off. I've got a good 60-70 flights on my World models F-82 and those two OS .46's h |
