Adjustable flap and elevator
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Adjustable flap and elevator
Page: [1]
Login
Adjustable flap and elevator - 3/10/2005 2:31:02 AM
2BFlying
Status: offline
This is the way I have set up my flap/eleveator linkage. It is fully adjustable and the rod is threaded steel rod 4-40 that I thread myself. This is not the finished product, just the setup to check for clearances. Note the notched flap.
Click to see fullsize image.
Click for fullsize
_____________________________
RWCherry
Sharpsburg Ky
       Post #: 1
RE: Adjustable flap and elevator - 3/10/2005 3:01:46 PM
kdheath
Status: offline
Two notes for you, RW. Normally, the bellcrank-flap pushrod goes in the top hole. Was just looking at my Pathfinder and the elevator pushrod attaches one inch from the center and the flap pushrod out one and a quarter. Then the elevator pushrod attaches one inch from center at the elevator. So the flap and elevator move the same amount or 1:1. Check your plans-perhaps this is the way it's drawn, but it's not the usual way.
If you use the steel clevises, keep a close eye on them. They sometimes fail in CL use. Threads can fail or the clevis can open. The stresses on these are higher than in RC uses. Put a nut behind the clevis and lock it down on the threads, and secure the clevis against opening with a piece of fuel tubing slipped over the clevis. And check them regularly. I've gone to ball joints on almost everything I build.
Keep up the good work!
Kelvin
(in reply to 2BFlying)
       Post #: 2
RE: Adjustable flap and elevator - 3/11/2005 12:03:22 AM
2BFlying
Status: offline
kd
I wasn't sure about the ratio, I thought that the elevator should have more deflection than the flap, say 1.5 to 1. But I will check the plans and see what they show. I really trust the clevises, but I thread all my rods and there is no slop in them. I use a split die and I open it up to give a slightly larger O.D. on the finished threads. The clevis fits better on my rods than a 4-40 nut on the same rod. Then they are LocTited with blue LocTite and never move unless I move them. I have used them on my R/C planes ever since I have been flying. My 3D plane is severely thrown around the sky and I have tried to get a failure from any of my construction but haven't. My pattern plane can reverse roll directions in an instant . I try to see if anything will break so that I will know how far to push the flight envelope and if it does then build it better.
This is not a show plane that I am building, that's for later. This is going to be used hard and often, whenever I can step out the back door and the weather is good. Here's my Twister and I'm still making a few final adjustments to it.
Click for fullsize
Click for fullsize
RWCherry
Sharpsburg Ky
(in reply to kdheath)
       Post #: 3
RE: Adjustable flap and elevator - 3/11/2005 4:56:53 AM
kdheath
Status: offline
I thought that those pushrods looked like above average work. You've taken a good bit of trouble to get them right. I expect they'll be fine. But it doesn't hurt to ask and be sure. Hope you didn't mind.
A lot of flapped ships use elevator/flap ratios of 1:1 or close to it. All the Twisters I can remember were close to the 1:1 ratio. A ratio of 1.5:1 is fairly radical as a starting point.
The Twister is such a good plane to learn the pattern. Dumb me, I skipped from the Busters and Skyrays to a Brodak Pathfinder. But now that I'm more comfortable with it, I wouldn't want to go back. Nice bird, enough so that I'm working on a mate for the first one. Gotta get my square manuevers under control this summer.
Kelvin
       Post #: 4
RE: Adjustable flap and elevator - 3/11/2005 5:59:40 AM
2BFlying
Status: offline
kd
I have excellent travel on flap and elev. and they have no resistance. Turn the plane over and they will fall that way. So if I have 1 1/2 inches of movement in up and down mode on my elevator I should have the same on the flaps,right? I made sure when I set the moving parts that I had plenty of travel. All surfaces have enough freedom to go almost vertical in up or down position without binding. My 3D plane has almost 3 inches of travel each way on the elev. and I have to gear my thinking toward C/L. It IS different from the R/C world in the control surfaces department. Have things thawed out in Minnesota yet? It's snowing now here. I'll check everything out when I get to the house and make some adjustments. I had a Buster and a Shoestring Stunter in the early 70's and they were great fliers. And about every Ringmaster made in the 60's. Oh, a quick question and you might know. Who makes the best quality kits in your opinion? This kit was so much fun I want to get started on another. Instead of spending 200-300 dollars on just the radio equipment for another R/C, i think I had rather put that money into a really good kit.
RWCherry
Sharpsburg Ky
       Post #: 5
RE: Adjustable flap and elevator - 3/11/2005 1:10:06 PM
downunder
Status: offline
I use a somewhat different idea behind setting up the elevator/flap ratios. On initial flights I set the flaps for absolute minimum movement (zero in fact) and do the first trimming flights using only elevator. In these flights I just check for wings level upright and inverted, enough tip weight etc before going into loops and squares. I use these to set elevator travel to get the feel I want combined with sharpness of square corners. Elevator movement usually comes out at +-17 degrees or thereabouts.
Once that's set I concentrate on looking for any trace of stalls in hard turns and they always show up in the last corner of the triangle and hourglass. This means more lift is needed so then I'll start setting the flaps to barely move. Each flight I'll increase flap movement until there's no trace of a stall in the tightest of turns then leave them. My flaps move about +-5 degrees but the model has a very light wing loading.
The point about using the least possible flap movement is that flaps add drag and this drag comes at the worst possible moment, just when you want to keep all the speed possible during a hard turn.
       Post #: 6
RE: Adjustable flap and elevator - 3/11/2005 2:24:16 PM
Fix-it
Status: offline
Nice looking bird! I am in awe of your bravery, if my wife found me working on our "Good Table" in the "Dining Room" I'd be eating off the workbench in the Garage!
For quality kits check out Brodaks, RSM, Walter Umland ( BuiltRight Models ), Richards Kits. There are more but I am going from memory.
I can not say I have built from all of these, but have seen either the kits or the completed planes. Get a copy of Stunt News and you will find these suppliers and other ads in it. Brodak kits are available at many hobby shops, the rest are usually obtained through mail order. LoneStar Models, Virginia Hobby Sport, Stuka Stunt Works, all have kits and supplies available. Google any of the above names and current links to their sites should show up.
Wheher a.k.a. Fix-it
If it's broke - Fix-it! If it's not broke, let me see it for a minute.
       Post #: 7
RE: Adjustable flap and elevator - 3/11/2005 8:24:13 PM
kdheath
Status: offline
Hey, RW,
Sounds great that the controls are very free. On a CL model, you don't have the servo to return the surface to neutral, so they need to be very free. But you don't need tons of throw. Try setting your control throw to about 30 degrees maximum. Huge throws will just act like brakes. My Pathfinder controls are set up for about 26 degrees of throw each way, and it will turn on a dime. If you have one of those RC throw measurement tools, that might be handy to figure out about where you are. Just don't max out the throw. Less is more.
For kits, Brodak has very good quality in a wide variety of designs. I've built several and only had a few quibbles with them. Most can be built straight from the box and be just fine. If you don't mind spending a little more for top drawer kits, see Eric Rule at RSM Distribution, Larry Richards at Richard's Kits, Randy Smith at Aero Products, and Ultra Hobby Products. When Walt Umland is making kits, they are wonderful, too. But he hasn't been doing much of late. They all have web sites, and do A#1 work.
Here's a list of most of the CL suppliers that's fun to rummage through:
http://home.att.net/~philbrown36641s5/clhomepage.html
All the kit makers are listed, I think. Let me know if you have trouble finding any of them.
What did you have in mind? Another profile? Old timer? Semi scale? Or a full-blown stunter?
Kelvin
quote:
ORIGINAL: 2BFlying
kd
< Message edited by kdheath -- 3/11/2005 8:27:56 PM >
       Post #: 8
RE: Adjustable flap and elevator - 3/12/2005 12:14:03 AM
2BFlying
Status: offline
kd
You were right about the control linkages. I changed them this morning when I got home and now have the same throws on elev and flaps. I measured them at 40 mm each way, but I will check them for degrees of movement. You suggest no more than 30, right? Sounds good to me.
Here's my experience from the past. Ringmaster and Shoestring Stunter, flew great and I had a blast with them. ( this was late 60's). Got a Nobler for Christmas from mom and dad. Built it and flew it. But it just didn't have the response that my profiles had. It seemed slow and lazy. Now that I reflect back, I think I did not have enough engine on it. The biggest I had was a McCoy 29, and it flew the Ringmaster great, 42 inch span, I think. When the barbed wire fence ate the Ringmaster, I put the 29 on the Nobler. Back then I was mowing yards for a living after school, funds were limited. (This was before I got more interested in girls)(or had a car).
I just want a top quality kit, with good wood. The Twister (SIG) was fair, but I had to buy some straight spars. I have mixed feelings about full fuselage and profile, don't really know which way to go. I have more 40 size engines, couple of 60 size, and a 90 in a four stroke. I like the 48 inch plus spans. But mostly I want a good quality kit. What is the best kit YOU have built? I am going to check out your suggestions.
Full fuselage planes are heavier than profiles so they need bigger motors. But I see where a lot of people use the 40 size on the Brodak Nobler, right? Isn't this around 52 inch span? But apparently this combination works well. Thanks for the input. I doubt I will ever compete, I just want to be able to throw the plane around the sky and have fun. I would like to spend a whole day flying, and that's hard to do with R/C.
RWCherry
Sharpsburg Ky
       Post #: 9
RE: Adjustable flap and elevator - 3/12/2005 9:24:10 PM
kdheath
Status: offline
RW, that's neat history. You sound pretty much like me-messing around as a kid. Had a Jr Ringmaster, CG Buster with a Fox Rocket 35, couple of Guillows Trainer IIs, a Veco Brave that a friend let me have. (I still have the O&R 23 that was in it.) Bunches of CG 1/2A things like the Lil Toot.
Actually, if you were to compare similar profile and full-fuse planes, all else being equal, the built-up will be lighter and stiffer. You can make fuselage sides out of 1/16th inch balsa on a 40 size stunter. Look at how much wood is in a 1/2 inch slab of balsa. I've been messing with a Brodak Fancy Pants kit. I really dislike the fuselage on that plane and am drawing a new design fuse around the wing. But anyway, I built a replacement fuselage using Tom Morris's truss method. The rear half of my test fuse (From the center of the wing aft) weighs 10 grams. Built of 1/16th sheet and 1/8th square sticks. And plenty strong.
The kits I've worked with that are great are those from Walt Umland, Larry Richards, and RSM. I haven't seen these myself, but all reports are that the Ultra Hobby, Randy Smith, and Tom Niebeur(sp?) kits are outstanding. Then there is a kit cutter named Joe Grasso. I have two of his RC kits and they are easily the best I've ever seen. Period, end of sentence. I have never, in 40 years, seen anything like his work. Amazing. The bug in the soup is that he only custom cuts small quantities. Now, a couple of us are looking for a design that we think significant enough to ask Joe to do a handfull of kits. One that we are excited about is the Steve Buso Hercules. Have a look at the Aero Products web site under plans for a small sample. If you think you might be interested, let me know and we'll keep you in the loop about our progress. Or if you have a suggestion, we'd be glad to hear it. The kits I have of his were $165-175. Not cheap, but a very good value at the price. All hand work.
Edit for the Nobler. The Nobler was designed around the Veco 31 and Fox 35 Stunt type motors. The 40s are actually overkill. They are more power than is absolutely needed for a Nobler and are heavier than the classic Fox. Not to say that a 40 Nobler isn't fine, it is. It's just not the only way to go. A light Nobler will fly pretty well on a good 25. It's likely that the wind will push it around, is all.
Regards,
Kelvin
ps I hear the Walt Umland has sold his line of kits. I can't verify that.
< Message edited by kdheath -- 3/12/2005 9:29:16 PM >
       Post #: 10
RE: Adjustable flap and elevator - 3/15/2005 12:10:04 AM
2BFlying
Status: offline
kd
Come to think about it, all my R/C planes have built up fuselages. My Razzle is the lightest of the corral and it is just triangulated spars, no sheeting, covered in Ultrakote. You can see thru the whole plane from the tail to the trailing edge of the wing. I think the engine and radio gear weigh more than the plane. With a 5 mph wind it has to have a little throttle to land. A few times I wondered if it was going to come down at all.
I have seen a few threads on the built up profiles, (like you mentioned), and it really looked good. You must understand, I have been out of C/L for a while and a lot has been improved on. I was just building and flying from what kits the LHS had in at the time, and I think the Nobler kit I had in '68 only cost 18 dollars. But I was a kid and having fun and wasn't in to the serious building aspect. But now I look at it a little differently. I have the PATIENCE to take time to do it right and well. Aftre raising 3 kids you learn it or go crazy. I'm going to check out the Aero Prod. site and see what you referred to. Thanks for the help. I am ready to fly. Twister is ready and two R/C craft are on the charger. More snow yesterday, 3 inches. May have to make some skis.
RWCherry
Sharpsburg Ky
       Post #: 11
RE: Adjustable flap and elevator - 3/15/2005 3:22:08 AM
kdheath
Status: offline
Geez, you have more snow in Kentucky than we have in SE Minnesota. Ours keeps melting the day after it falls. At least we've had enough to keep the summer from being so dry.
       Post #: 12
RE: Adjustable flap and elevator - 3/15/2005 7:15:01 AM
2BFlying
Status: offline
kd
Found the web site okay but no information on Steve Buso's HERCULES, only a price for plans. I looked at Brodak's VECTOR 40 and it looks pretty good along with their LEGACY 60. RSM's site is good but most of theirs are Old Time Stunt. Aren't these tried and true designs? Most of them won Nats in the 50's and 60's. But I am intere
