Just built a SPAD Foamie!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Just built a SPAD Foamie! Page: [1]
Login
Just built a SPAD Foamie! - 3/12/2005 5:31:28 AM
-pkh-
Status: online
I just built that "SPAD" foamie that's posted on the http://www.spadtothebone.com homepage... if your interested, check out my thread in the Electric Foamie forum by clicking on the link below...
My SPAD Foamie Thread
I posted it there, since it's really more of an electric foamie than a SPAD... but figured my fellow SPADders would be interested as well... especially since the plans are listed on our favorite website...
_____________________________
Paul - Helis: Two Raptor 50V2s, Venture 30CP, Blade CX2
Planes: Twist 150, Twist 60, Tribute 36, GP .40 Mustang
       Post #: 1
RE: Just built a SPAD Foamie! - 3/12/2005 7:10:33 AM
FrankC29
Status: offline
Hey cool someone actually built my design! I can tell you why you ended up adding tail weight. The pack you are using is an ounce or soheavier than the Etec 1200mah pack I used, so your AUW is a bit heavier than the prototype by an ounce and a half, but no big deal, it should still fly great. Not a great looker I know, but you would be VERY hard pressed to find a FFF sport plan that is as quick and easy to build. It flies great too.
< Message edited by FrankC29 -- 3/12/2005 7:13:47 AM >
Save Trees...fly S.P.A.D.
Frank Costa
(in reply to -pkh-)
       Post #: 2
RE: Just built a SPAD Foamie! - 3/12/2005 2:38:43 PM
Smooth Spanky
Status: offline
pkh:
I like it! Let me know how it flies!
(in reply to FrankC29)
       Post #: 3
RE: Just built a SPAD Foamie! - 3/12/2005 10:57:54 PM
-pkh-
Status: online
FrankC29... Great design! Thanks for posting those plans on STTB! You're right, it was a pretty quick and easy plane to build.
I figured the bigger pack was probably the reason mine came in nose heavy. I believe this pack is longer than the 1200mAh pack, and I think I have a little more space between the pack and the motor, which puts the wing back farther than yours, making it more nose heavy. I put a 3/8" square balsa piece between the batt and motor to be sure the batt doesn't slide up against the rotating outrunner case. I also put some 3/8" balsa under the wing, and where the rubberband mounts go into the fuse... the rubberband tension was bending the fuse up at both ends, so I had to stiffen it up a bit.
I did maiden it today... just one flight, though... check out the other thread for details...
My_SPAD_Foamie_Thread
< Message edited by -pkh- -- 3/12/2005 11:05:17 PM >
(in reply to Smooth Spanky)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU2
