Bill Vargas
CA, USA Status: offline
Brad, have you tried using a jewlers screwdriver inserted into the hole with the broken screw? Sometimes when a bolt breaks off, like in your case, there's a burr on it that just might be big enough for the screwdriver to catch on to thus permitting it to be backed out. You may also want to apply a little bit of heat with a heat gun to make the broken screw come out a little easier,,, but if you think that screw bottomed out when it broke, chances are it ain t coming out. Another idea,,, as you said, "it is too far down inside the hole,,," try a shorter screw and if you can get at least 3-4 threads into the hole, you should be ok(Use your dremel to make the replacement screw shorter). Just make sure the backplate is fully seated before torquing down the screws BV
_____________________________
If it ain't leaking oil, then something's wrong,,, USMC, RETIRED!
