CRSMP5
Joined: 7/27/2004 From: Vienna, OH, USA Status: offline
have not drove it yet. its got soem neet things.. and some annoyances like to get the electronics out takes a good 30 min to just get them out.. it has 4mm cap head screws that are self tappinf/wood screws, there is alot of slop where things need shimmed, th eball ends onto balls are all loose, the shocks are hpi specific size so hpi only springs can be used, the radio box is not water tight, you cannot fit a p5 into it without modding the purple engine plate, so that means ws7II and other engines will have the same issue, the engine mounts are a odd ball size, kyohso might fit, but my mass supply of hb ones are a no go, basically it is a hpi only parts truck.. nothing else will fit and their tolerances in my opinion are way too losse for a truck ment for racing.. the instructions are nice.. they copied the x-ray in the fact it explains what set ups do.. and this and that adjustment..
_____________________________
www.truggyracers.com
