RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, Conversions..etc...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, Conversions..etc...
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, C... - 4/3/2005 11:07:35 PM
IslandSavage
Status: offline
Took it out for a street run toady/.... SMOKIN!!!!!!!!! This thing picks up and GO'S... I was having a issue with it cutting out at full throttle though. I leaned it out and it worked fine, but when i richened it would cut out. I think personally my Glow Plug is bad...I dont want to have to lean it out too much just for it not to cut out....I had this problem with my MGT and a new glow plug fixed the problem.. Oh well (they dont last forever).. I fitted in a fuel filter as you can see from the new pix. I also changed the routing of the fuel tubing. Also for the question about my transponder location, if you look at the steering servo horn you'll notice the hiles where the transponder mount goes.... I havent properly secured the Aux tank, but I was planing to use a rubber cement compound. It will hold perfectly. But im going to try and run some long enough Zipties under the side body mount and over the tank. It should work fine. I just wanna tryi it before i use the compund. Zipties will make for easier maintenance(as long as it hold good, but it should)...
So now, all I need is to paint the Body (no idea what color), Mount it, and buy a new glow plug
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Savage 25
Mugen Seiki MBX5 (REX P5)
(in reply to IslandSavage)
       Post #: 176
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, C... - 4/4/2005 12:13:05 AM
IslandSavage
Status: offline
If the Hot Bodies tank (145cc)is a direct drop in for my Truggy, then i would get one, but i would also keep the Aux tank.. More fuel..more run time
Savage 25
       Post #: 177
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, C... - 4/4/2005 1:54:42 AM
hybridstone
Status: offline
So what I read your saying the header tank gets filled as well while filling the main tank?
Go hard or go home!
       Post #: 178
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, C... - 4/4/2005 3:12:55 AM
cemeb4dk
Status: offline
I have the maxx size crowd pleazer on my k2 truggy. I just bought the revo 2.0 crowd pleazer by Pro-Line. I like the looks a little better (its a bit bigger than the tmaxx one). The only issue is the front stock body posts spots are dimpled down, so you have to drill your body holes just behind the stock dimples.
MP 777 w/king headz hop ups rex P5x/O.S. 2050
Lightning Stadium Pro w/King Headz NR 528XR w JP1
(in reply to hybridstone)
       Post #: 179
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, C... - 4/4/2005 4:20:22 AM
IslandSavage
Status: offline
quote:
ORIGINAL: stonesavage
The header tank always stays filled from the initial fill-up before the race. It only runs out when your Main tank is dry. Then the (60cc) gets used. When you refill the (125cc) while you drive it dumps over into the Aux tank to fill the portion of it you used back up.. Think of it as a reserve tank. When i race i refill at the 125cc mark. most people refill around or before this mark even with a 150-160cc tank. but remember the 1st thing about a header tank is the header tank is a simple/effective way to ensure your engine gets a consistent fuel flow, and acts as a reserve with (60cc) of fuel.hmmm check this....
we both run a long main.. you have (160cc) i have (185cc total).... at 125cc you pit..i strecth out more lap time cause i know i have a reserve and wont run out so at 155cc I pit. now your at 35cc left and im at 30cc ...after refill your back to 160cc and i refill the main tank at 125cc so now im at 155cc..part of the 125cc i refilled will go to the Aux tank to refill the 30cc i used of it. so now my main tank is at 95cc but my aux is back to 60cc so my total now is 155cc.. so if we have to pit again im already ahead cause i squezzed out more laps cause I had more fuel to run...
Click for fullsize
Savage 25
       Post #: 180
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, C... - 4/4/2005 4:32:37 AM
hybridstone
Status: offline
I get ya!thanks Island
Go hard or go home!
       Post #: 181
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, ... - 4/4/2005 4:51:35 AM
cemeb4dk
Status: offline
If you stretch it to long, Hypotheically. Say you run the main tank dry and you have just a bit of fuel left in the aux tank (just about gone say running on fumes). Tehn you pit and refuel your main tank. Will there be enough pressure to push/pull fuel into the header and then to the carb, since your fuel outlet is lower than carb height, and you are strictly counting on exhaust pressure.
This is just one thing I noted in your comments and pics. When I had the Savage with the header tank, everyone everywhere said that the fuel outlet to the carb had to be above carb inlet heigth.
Don't take my comments the wrong way, in no way am I bashing, just trying to give soem thoughts and perspectives and hopefully solve a n issue before it comes one
       Post #: 182
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, ... - 4/4/2005 5:14:14 AM
badboy2
Status: offline
i want the hb lsp
< Message edited by badboy2 -- 5/16/2005 4:36:08 AM >
SAVAGE QUARK125/8XL,MGT W/lc32,LSP W/REX28, inferno gt,REVO,E-PEDE,MP777 SP2
(in reply to cemeb4dk)
       Post #: 183
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, ... - 4/4/2005 5:18:10 AM
cemeb4dk
Status: offline
badboy give us the item number
(in reply to badboy2)
       Post #: 184
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, ... - 4/4/2005 5:21:20 AM
Monster Flip
Status: offline
i think thats pretty good....doesn;t the conversion kit alone cost $100 +?
Twin TITAN
RACIN AZN' Like Hoy!
       Post #: 185
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, ... - 4/4/2005 5:29:53 AM
badboy2
Status: offline
..idk if i can post link from ebay here
< Message edited by badboy2 -- 5/16/2005 4:36:42 AM >
(in reply to Monster Flip)
       Post #: 186
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, ... - 4/4/2005 1:13:46 PM
IslandSavage
Status: offline
quote:
ORIGINAL: cemeb4dk
The Pressure from the Main tank still pushes all the way to the carb. If the Aux tank is damn near dry and i refill the main tank, it still runs. The fuel is being pushed into the carb from the aux, from the main. The pressure remains the same wether full or low. I tried and tested this already. I even started with no fuel in the aux just in the main tank and fuel lines to simulate a situation like you stated. It kept going and refueled the aux tank at the same time. Aux tank position isnt as important ans a constant pressure in the lines. I placed the tank in many positions (Flat, sideways, left,right up, down, backwards, even hanging out the side.) I ended up with the same result. I found the lying flat position to work best for me cause it lowers the CG also... These are my resluts and findings, im not tryingt to rewrite a physics book, but it worked for me
Savage 25
       Post #: 187
RE: Official ALL TRUGGY THREAD.. Hotbodies, GS, ... - 4/4/2005 2:04:39 PM
cemeb4dk
Status: offline
Cool, Glad it worked and you tested it. Like I said before wasn't trying to bash, just would hate for you to find out during a race. I wish my races would allow an auxillary tank.
