Balsa Steel
OK, USA Status: offline
You can't go wrong with the Spectra (in my opinion). Other than the previously mentioned faulty tailplane design, I have no complaints about anything on mine and it's 100% factory stock. Below is a post I made back in January: The Spectra Select was the plane that got me hooked on sailplanes. Mine's been through 3 ($7.50) motors so far. In stock form, the plane is good for 2-3 climbs depending on all the weather variables and it climbs at an adequate rate. Like everything else, you can upgrade batteries, motor, etc. and get different results, but I'm keeping mine simple and cheap and I have no complaints. Considering the heavy wing loading, it thermals surprisingly well, and the resulting faster speed gives it good authority on the stick. Don't try to stretch the glide out too much because it will drop a wing without warning, and it doesn't recover quite as quick as you would think. The only problem with the airframe is the horizontal stab attachment. Somebody needs to tell the manufacturer that glue does not stick to covering. It is not safe, glue some triangle stock to the bottom before your first flight. My shortest flight ever was yesterday at 16 minutes and my longest was just over an hour back in October. When this one finally bites the dust, I'll order another exactly like it, and fly my Bird Of Time till it gets here
