hilleyja
WV, USA Status: offline
quote:
ORIGINAL: mglavin There are no program limitations known at this time, less the deviation from programmed parameters. I have provided this information in detail many times to date. The v1.04 revision digitals can be used once programmed, they have proven to work without issue and or any reliability shortcomings. Hitec USA is expecting a programmer update within a few weeks which will address the noted deviation/offset ONLY... Once we have the update in the USA, some local testing and review will be initiated and immediately thereafter the programmer updates will be made available to all, free of charge. Customers without programmers may return their servos to Hitec USA for reprogramming. Though, I review these forums extensively, I do not remember inputs from you on this subject that speaks to my question -- certainly not in this particular thread. Until P-51B bumped it there was no response to my question at all. I see you removed my post about this thread being ignored by Hitec -- how would you interpret no response a month after asking the question. As far as my question: I'm sorry, just call me super dense because it still doesn't seem to have been answered. Maybe this will help -- I'll repeat my question a little differently: What programming function can or can't be done on a version 1.04 servo (it now appears that the 5995 servo is not the only one) using the 1.03 programmer? (This is the gist of my question "What are the current limitation on programming for these servos...." What happens if I inadvertently reset the servo using the current programmer, etc....?
_____________________________
Jim Hilley AMA #671825 RCCA# 758 Twist 150 Brotherhood #14
