Hornet II Main Rotor Shaft Pins.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Hornet II Main Rotor Shaft Pins.
Page: [1]
Login
Hornet II Main Rotor Shaft Pins. - 3/14/2005 3:41:30 PM
YYCS
Status: offline
I have a Hornet II which includes the MS E230 one way bearing and main gear setup. The problem I have is that the pin they give you to secure the one way bushing to the main rotor shaft falls out. It is so loose, that once I get it in and spin the shaft, the pin slides right out. I am thinging of using a piece of a paper clip, and "z" bending the ends. I also thought a little dab of epoxy might work on both ends of the pin. Anyone else having the problem, or any suggestions??
       Post #: 1
RE: Hornet II Main Rotor Shaft Pins. - 3/14/2005 4:30:42 PM
GentleBen1952
Status: offline
I have the same setup that you do. Make sure there is no slop on main shaft, that will help the little pin lock in. I also put a small drop of CA on both sides of the pin and have not had any problems. Plenty of other stuff coming loose but not that pin. If you decide to replace the pin use piano wire from LHS not paper clip.
_____________________________
Are we having fun yet?
(in reply to YYCS)
       Post #: 2
RE: Hornet II Main Rotor Shaft Pins. - 3/14/2005 7:41:03 PM
davbow
Status: offline
take a piece of fuel tubing and put it around it... works great
(in reply to YYCS)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
