mulligan
FL, USA Status: offline
Ben, I'm following you around in these threads it seems Downwash is often thought of as the cause of lift. Rather, it is a result. Everyone (well, ok, let's not go there) knows Bernoulli effects cause accelerated flow and lower pressure over a curved surface. In an airfoil, when this happens (moreso) over the upper surface, it causes a flow field around the ENTIRE airfoil. While most people think about the downwash at the TE of an airfoil, many do not talk about the upwash at the LE. Both are a part of the overall flow field around/over the airfoil. You won't have downwash without an equal amount of upwash at the front (m dot in = m dot out). I wouldn't begin to think of downwash as an independent force on the airfoil- it makes the whole analysis a sequential discussion, when the physical phenomenon is not. The idea of a reflexed airfoil in a flying wing is simply a means to shift the pressure distribution so the natural moment isn't as great, since you don't have a tail moment for pitch control. These airfoils are not as efficient (L/D), but that is offset (presumably) by the drag savings of not having a tail.
< Message edited by mulligan -- 3/17/2005 5:03:34 PM >
_____________________________
George Mulligan www.sanfordaeromodelers.com
