pwterry
NC, USA Status: offline
paedbo, Did you retime the stock 370? How? I've been thinking about straightening the four crimps holding the brush plate and turning the plate a little to advance the timing. Is my thinking correct? batfalcon, If the Twister is just like the HB2, all three servos are used for both pitch (collective) and cyclic movements. For collective, all three servos pull the swashplate down. For left/right cyclic, the rear two tilt the swashplate. For foreward/backward cyclic, all three are used to tilt the swashplate. Lessening the movement of any one of the three will throw everything off.
