TManiaci
CA, USA Status: offline
JNorton, Glad to see another F90 lover. You will rock with the servo selections, just keep those linkages TIGHT and with maximum mechanical advantage your control horns will allow. Echoing everyone else... SLOW is this birds world. Your engine selection is pretty weak, no offense. If you really don't want 3D, you'll be fine. But, this is one canary that loves to 3D. I'm a pattern guy too, novice learning 3D. The thing is, when you have a bird that can go berserk, you will want to go berserk too. The recommended Saito 100 is marginal for agressive 3D, so your Magnum selection will leave you way short. Just a suggestion... think about growth and your ever improving skills. The CG you are targeting is not happening. 6-1/4 with a light motor like this will require many oz's in the nose to get there. You will find a VERY docile flying creature with CG at 6-3/4"... greasy landings and no funky tail-heavy tendencies in the air. Even with pull-pull on the Rudder, and Y-link on the elevator in the fuse, you are still well behind the 7-1/4" factory CG, which is recommended for strong 3D performance. My "guess" is, you will CG at 7-1/2 or more with your setup plan. A heavier motor (with more power) can fix this better than adding lead. I hope I'm wrong... but don't be suprised. Adding balancing lead to an underpowered plane is not happiness. Control Throws: I am really happy with low rates at 1" on both Aileron and Elevator, 2" on Rudder. This is actually a little touchy, and I used 40% expo to soften it up a bit. High rates are whatever you can get with good mechanical advantage, but these low-rate settings allow some pretty radical stuff! This thing has WAY more control than you need for good pattern flying. It is a beauty... and a MAJOR BLAST to fly. I'm new to this too, and totally addicted now. You will not be dissappointed.
< Message edited by TManiaci -- 3/18/2005 8:07:19 PM >
_____________________________
TMan
