combatpigg
WA, USA Status: online
SR77 , that cowl is AWESOME! You are a visionary genius! I was just giving ANDREW D a hard time about his, "build the plane to match the dime store cowl" technique, and then you come up with this! I'll bet that plastic is heavy though, is there any way you could shorten the bottle and still retain the coolness factor? If you have a scale, weigh that sucker. I wouldn't allow myself more than an oz of weight allowance for the cowl, and hopefully less than that. That plane would still look very cool if you cut over half of the cowl away[ IMHO]. If you shorten the nose then you will be moving in the direction that DB mentioned so it's a win- win situation if you can lose weight and gain better flying characteristics at the same time. And we gotta have a talk about that landing gear too.......it's just for display, huh? BTW, the SAFEWAY job ended, so I am going to have lots of free time for awhile now, and I'll be in touch to set up a plane smashing session with ya !
< Message edited by combatpigg -- 3/19/2005 1:52:03 AM >
_____________________________
Led Zeppelin is NOT "old fogie" music.
