Extreme Flight 87" Yak 54 - Cockpit Build
Tower Hobbies
Logged in as Guest
  Printable Version
Wow! H9 33% Cap 232 New in Box! No Haggle Price!
Seller:  Dustflyer
Details:   $550.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Extreme Flight 87" Yak 54 - Cockpit Build
Page: [1] 2   next >   >>
Login
Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:25:58 PM
Kregg
Status: offline
This is the beginning of a rather long thread showing the build of a custom cockpit kit made for the Extreme Flight 87" Yak 54. The complete photo kit only weights a couple of ounces. I built this kit out of 30+ digital photos, that were retouched, distorted, illustrated into cockpit photos that look like you are seeing inside the Yak 54. The photos I used are all from real aircraft very similar to the Yak 54. Most of my images came from photos of a Pitts M12. Given that, this cockpit is scale quality, but not exact scale to a actual Yak 54. To wet your appetite, here are the photos of the finished kit installed in the Yak canopy. As you can see the canopy still needs to be painted for the panels lines and edges. I have created a rear cockpit with a pilot in the seat. The torso of this pilot gets covered up by a regular pilot bust and looks great. I also have a version of the rear pit witout a pilot at all. This version is just darkened with shadows so it does not look like a floating shark biten pilot bust that is floating when installed.
Send me a direct e-mail (kregg@wrightrc.com)if you are interested in one of these.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Kregg -- 3/24/2005 1:51:38 PM >
_____________________________
Virtual Cockpit Kits (www.wrightrc.com)
They look like the real thing and only weigh a couple ounces!
       Post #: 1
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:27:57 PM
Kregg
Status: offline
Step 1
I made exact templates for all of the needed cockpits and dash panels.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 2
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:29:52 PM
Kregg
Status: offline
More templates...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 3
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:31:13 PM
Kregg
Status: offline
This shows my final templates. I trim to fit just right and then scan them into my trusty Mac.
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 4
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:32:45 PM
Kregg
Status: offline
Step 2
Use black marker and hide several areas of the canopy structure that will be visible after the kit is installed.
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 5
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:34:43 PM
Kregg
Status: offline
Step 3
Many, many, many hours of photo retouching later I have developed these photographic cockpit visuals and fit them perfectly into the new digital templates.
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 6
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:36:31 PM
Kregg
Status: offline
Step 4
Build the rear dash board and cut the slots in the base for the dash attachment. Carefully cut the individual tabs and fold them. Do not tape to base yet.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Kregg -- 3/19/2005 5:42:37 PM >
(in reply to Kregg)
       Post #: 7
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:38:27 PM
Kregg
Status: offline
More rear dash assembly. Cut slot holes in the base for an easy slide fit.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Kregg -- 3/19/2005 5:44:30 PM >
(in reply to Kregg)
       Post #: 8
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:47:39 PM
Kregg
Status: offline
Step 5
Remove the rear dash and start inserting the individual templates into the canopy. Carefully curve the graphic prints to fit in through the rear. Do not bend or fold. Anchor each piece with heavy duty 3M fiber tape from the bottom of the canopy. Support each panel from the inside with your hand to get a tight fit and firm tape surface. Install the assembled rear dash before adding the front graphic panel (see photo).
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Kregg -- 3/19/2005 5:49:29 PM >
(in reply to Kregg)
       Post #: 9
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:49:21 PM
Kregg
Status: offline
More installing and taping...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 10
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:50:46 PM
Kregg
Status: offline
More installing and taping.... After all panels are installed add additional fiber tape for a strong bond.
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 11
RE: Extreme Flight 87" Yak 54 - Cockpit Build - 3/19/2005 5:55:59 PM
