COMPOSITE WING GLASS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> COMPOSITE WING GLASS
Page: [1]
Login
COMPOSITE WING GLASS - 3/20/2005 2:34:52 AM
filtr-RCU
Status: offline
HI FOLKS
I WAS WONDERING IF ANY CAN HELP ME. I HAVE A SET OF MOLDS MADE FOR A PATTERN SHIP. I WAS WONDERING IF SOME ONE KNOW WHAT WEIGHT OF CLOTH THAT IS BEING USED AND AND WHAT WEIGHT OF BALSA PEOPLE ARE USING FOR A WING.
RON
       Post #: 1
RE: COMPOSITE WING GLASS - 3/20/2005 3:33:22 AM
Mluvara
Status: offline
I believe in general, 2.5oz on the outer layer and 1.5oz on the inner layer is pretty typical, with reinforcements where necessary.
_____________________________
Michael Luvara
RCATS - http://www.rcatsystems.com
Luvara Air Racing - http://www.LuvaraAirRacing.com
(in reply to filtr-RCU)
       Post #: 2
RE: COMPOSITE WING GLASS - 3/20/2005 7:30:57 AM
combatpigg
Status: online
I just built a plane with 1/2 oz cloth on the surface [first layer] , followed up with 2 oz cloth for the second layer. In some places you will want to use a third layer of 2 oz cloth. The balsa sheeted foam wing is typically done with either 1/16" or 3/32" thickness wood. I GORILLA GLUED a pair of aluminum engine mounts in.
Led Zeppelin is NOT "old fogie" music.
       Post #: 3
RE: COMPOSITE WING GLASS - 3/20/2005 1:10:20 PM
Ed Smith
Status: offline
Assuming this is a fairly large pattern airplane with a big fuselage. The first layer in the fuselage mold should be 2 oz cloth. This will prevent SOME of the inevitable pinholes. Follow this with two layers of 6 oz cloth. An aditional partial layer of cloth or carbon cloth could be used ahead of the wing to stiffen up the engine end. If you have carbon tow then wind some into a string and mold in at strategic high stress points. This method adds enormous stiffness and strength for very little weight. See picture.
If the wing is ordinary white 1lb foam I would recommend 3/32 wing skins. If the wing is heavier foam and/or has a spar system then thinner skins may be OK.
Ed S
Click to see fullsize image.
Click for fullsize
       Post #: 4
RE: COMPOSITE WING GLASS - 3/20/2005 5:40:23 PM
Mluvara
Status: offline
I think I misunderstood your first post and responded for building a hollow core wing. oops.
Ed's suggestions are good for a fuselage layup.
< Message edited by Mluvara -- 3/20/2005 5:42:34 PM >
Michael Luvara
(in reply to Ed Smith)
       Post #: 5
RE: COMPOSITE WING GLASS - 3/20/2005 6:01:33 PM
filtr-RCU
Status: offline
No it is a hollow core wing.
Ron
(in reply to Mluvara)
       Post #: 6
RE: COMPOSITE WING GLASS - 3/20/2005 7:30:04 PM
Mluvara
Status: offline
In that case, 1/16" balsa with the 2.5 oz outer and 1.5oz inner is appropriate. Some opt to do different things around the ailerons (if they are skin hinged). And appropriate reinforcement (carbon tow, glass tow, etc) around the spar is necessary.
There's a few threads around here in the composite forum regarding composite wing construction.
Michael
Michael Luvara
       Post #: 7
RE: COMPOSITE WING GLASS - 3/20/2005 8:18:06 PM
Deadstik
Status: offline
Ron,
Ed is right on the money as far as a fuse layup including the carbon fibre tow to increase strength with very little weight. His "formula" is the same as I use to layup my pattern ships.
Dan
Carolina Custom Aircraft
       Post #: 8
RE: COMPOSITE WING GLASS - 3/20/2005 10:41:54 PM
combatpigg
Status: online
The reason behind leading off with a first layer of tight weave, .5 oz cloth is so you won't see the heavy weave[of 2 oz cloth] and need so much heavy filler to finish the surface with. This method saves weight and has some structural value vs relying on dead weight fillers.
(in reply to Deadstik)
       Post #: 9
RE: COMPOSITE WING GLASS - 3/20/2005 11:10:15 PM
filtr-RCU
Status: offline
I am planning painting in the molds. If you look at the fuse in info that fuse is painted in the mold. Just moving up to the wings.
Ron
(in reply to combatpigg)
       Post #: 10
RE: COMPOSITE WING GLASS - 3/21/2005 2:49:29 AM
SCALECRAFT
Status: offline
If this is what your trying to do.
This model, of a 65"span Typhoon is layed up with aprox 5.0 oz glass with composite reinforcements. It is a free atmosphere layup. No bagging. The entire airframe, hollow wing set up for retracts, comes it at 3.25lbs.
Hope this helps
Steve
Click for fullsize
Click for fullsize
       Post #: 11
RE: COMPOSITE WING GLASS - 3/21/2005 1:46:32 PM
daven
Status: offline
On my Q500 wings, I'm using 1.4 oz on the outer layer, a 2nd layer of 2 oz over the hinge and trailing edge, then the rohacell 2 mm, and then a layer of .7 on the inside. On the bottom I add a piece of light CF cloth about 8" at the TE and fanning out to about 14" at the LE.
I paint in the mold also, and 1.4 oz is plenty light to get a good finish.
Dave Norman
klasskote.com
supertrc.com
(in reply to SCALECRAFT)
       Post #: 12
RE: COMPOSITE WING GLASS - 3/22/2005 2:04:09 PM
esamart
Status: offline
Steve!
You have quite a lot of work on your Typhoon? Anyhow I do not see any wing spar in the center section. I am afraid it wont take many G's to fail. Before flying I suggest you to make simple stress-test usinh bags filled with sand.
That type of construction is also prone to engine vibration. It sounds like a drum so glue seams fail in time.
Sandwich construction with designed carbon fiber spar/shear web would be a way to go in future. I hope you can use your current molds.
Esa
(in reply to daven)
       Post #: 13
RE: COMPOSITE WING GLASS - 3/23/2005 2:31:14 AM
SCALECRAFT
Status: offline
Esa
I see your point that it may be difficult to see the spar. So I'll make it a bit easier to see the concept we use. This is an 11 year old concept. It is fool proof and yet economical. In the 11 years we have been flying these hollow composite wings, we have yet to have an in flight failure. In fact, the corsair wing construction you see has been crashed 4 times with only retract damage and not the concept failing even on impact. I flew it yesterday.
Although not indestructable, they are very durable.
Vibration. Epoxy resin can resist vibration much better than polyester. We use only epoxy. Aramid is also used, it acts as a viration dampner(spelling?) on real airframes.
If I missed your point please post pics if your wings and fuses, I'm always willing to learn.
Any questions or comments please don't hesitate.
steve
Click for fullsize
Click for fullsize
(in reply to esamart)
       Post #: 14
RE: COMPOSITE WING GLASS - 3/23/2005 4:06:43 AM
