kmtranmd
OR, USA Status: offline
Just got my P-40 in the mail. Finish is pretty good, no wrinkles. Plane was built very light, but probably because there's hardly enough glue in it. Hangar 9 still has not dealt with the use of undergluing in their ARFs. Firewall area needed quite a bit of epoxy since hot glue marks seemed inadequate. Elevator servo mount gave away with only slight pressure, so had to get hit with epoxy also. Now, I'm wondering how many other areas are underglued. I plan to hit CA's in all spots I can get access to. Will see how it holds up when I maiden in couple weeks. Will see how the rotating retracts hold up to landings.
_____________________________
GI Doc
