bigtim
CA, USA Status: offline
I have read this before it must have been another thread posting about this same thing the lack of bell cranks, the ones supplied are not that great but they get the job done, you just need a L shaped bell crank on each wing side at the retract, and push rods from the center of the wing out to the bell cranks if you use EZ connectors to attach the push rods then you can tweek/adjust the rods for operation. here is a little tip, when you get the stock units in, there are little adjusting screws they are for fine adjustment don't worry about them at first you will use them later after a few flights. to get the retracts to go fully up and down find the locking sweet spot by slowly raising and lowering the retracts until you find the down locked, locking position. if you go past that position it doesn't lock em down more, then when you retract the gear they will fully retract into the wing mine had a habit of sagging down when retracted until I fooled around with them to get them just rite you will know what I mean when you start ajusting them after install. the EZ connectors make the adjusting easyer you can slide the pushrods and adjust them until they work properly. sorry I dont happen to have any inside the wing shots do you have the instruction manual if you don't you can down load it from www.horizonhobby.com it's posted there
