RE: Hangar 9 P-40 Warhawk
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Hangar 9 P-40 Warhawk
Page: <<   < prev  24 25 26 [27] 28 29 30 31 32 33   next >   >>
Login
RE: Hangar 9 P-40 Warhawk - 5/23/2007 8:32:25 AM
bigtim
Status: offline
I think there is a thread, on doing just that install here on RCU.
there is alot of info on after market retract installation in this thread it might take some time to find.
(in reply to BOLT)
       Post #: 651
RE: Hangar 9 P-40 Warhawk - 5/23/2007 1:01:54 PM
BOLT
Status: offline
Thanks for your prompt response. There's a lot of info on this plane. I'm still learning how to do an effective search but I'll keep trying. If you happend just to find find what I'm looking for please send me the thread.
_____________________________
Blessed is the man who has a hobby for he has two worlds in which to live.
(in reply to bigtim)
       Post #: 652
RE: Hangar 9 P-40 Warhawk - 5/24/2007 6:39:20 AM
bigtim
Status: offline
http://www.rcuniverse.com/forum/m_4929121/anchors_4929121/mpage_1/key_H%252D9%252CP%252D40%252Cwarhawk/anchor/tm.htm#4929121 and there you go somtimes you got to do some digging arround here, it was pretty easy hope this helps.
(in reply to BOLT)
       Post #: 653
RE: Hangar 9 P-40 Warhawk - 6/3/2007 2:41:06 PM
RCWI
Status: offline
HI, I'm using a os91 2 stroker with 13x8, it flys fine. But I have a 12x12 and tacked it at 10,000 rpms but havent flowen it yet with this prop. I dont think its to much but I dont want to snap the wings off of it. What is the fastest speed recorded for the hargar 9 p40? thanks for the info.
       Post #: 654
RE: Hangar 9 P-40 Warhawk - 6/4/2007 1:15:33 AM
bigtim
Status: offline
I fly mine with a 14/9 3blade it flys fine at 1/2 throttle .
fastest speed dont know about that, if you read through this thread there is a bunch of info on structural problems, I like the larger props myself but I have a 4st in mine.
(in reply to RCWI)
       Post #: 655
RE: Hangar 9 P-40 Warhawk - 6/4/2007 1:23:58 AM
RCWI
Status: offline
Thank you you for your reply. i guess to much speed will snap any bird in bits.
       Post #: 656
RE: Hangar 9 P-40 Warhawk - 6/4/2007 3:11:50 AM
lthibault
Status: offline
Well it's over with mine . Major engine problem caused sudden dead stick without any chance to recuperate.
This was my all time favorite war bird in the fleet.
Next project: H9 P-47 60 with the Zenoah G-20 Engine.
Luc
(in reply to RCWI)
       Post #: 657
RE: Hangar 9 P-40 Warhawk - 6/4/2007 3:48:09 AM
bigtim
Status: offline
a sad day indeed, I was flying mine today and am really starting to get it dialed in.
the 3 blade prop I am running really hauls it around less throttle faster speeds
(in reply to lthibault)
       Post #: 658
RE: Hangar 9 P-40 Warhawk - 6/4/2007 1:11:12 PM
RCWI
Status: offline
What do you mean, "less throttle faster speed"?
       Post #: 659
RE: Hangar 9 P-40 Warhawk - 6/12/2007 2:41:17 AM
RCWI
Status: offline
Does all p 40s shake their tail as they fly? mine has a shake and a twitch even with ni wind at all, Why do they do this and is there anythihng that can fix it?
(in reply to RCWI)
       Post #: 660
RE: Hangar 9 P-40 Warhawk - 6/12/2007 2:43:32 AM
tailskid
Status: offline
Mine never did even at WOT
# 93 in Club Saito
(in reply to RCWI)
       Post #: 661
RE: Hangar 9 P-40 Warhawk - 6/12/2007 2:47:15 AM
RCWI
Status: offline
Well if mine is and only mine can anyone think why mine does it? thanx
(in reply to tailskid)
       Post #: 662
RE: Hangar 9 P-40 Warhawk - 6/12/2007 2:53:38 AM
rustypep
Status: offline
Isn't it the canopy on the corsair that causes that wiggle? Sorry, never heard of it on the P-40 but I don't know the history that well. What engine and how fast are you going? Maybe you are going too fast...haha.
quote:
ORIGINAL: RCWI
Club Saito Member 354
(in reply to RCWI)
       Post #: 663
RE: Hangar 9 P-40 Warhawk - 6/12/2007 4:44:53 AM
bigtim
Status: offline
mine does get a little wiggle when I get going on a full throttle speed pass the rudder is pretty large and the control horns are not what I would call super stiff either.
what I meant by "less throttle faster speed" is with the 14/9 3 blade prop, my P-40 flys much faster at half throttle, than when I had a 14" 2 blade on it at 3/4 throttle.
this plane doesn't seem to need to go fast to fly great its so light, when I punch the gas it really takes off and seems to prefer to fly at 1/2 to2/3 throttle, at least mine does.
a shot from memorial day, nobody at the field but me and a couple of birds
Click to see fullsize image.
Click for fullsize
< Message edited by bigtim -- 6/12/2007 4:51:07 AM >
(in reply to rustypep)
       Post #: 664
RE: Hangar 9 P-40 Warhawk - 6/12/2007 2:05:07 PM
Edwin
Status: offline
Mine wiggles (or fishtails) too. Its pretty light at 7lbs 10oz. It starts its fishtailing about mid throttle on up to full throttle. Linkage is rock solid stiff (4-40 steel rod in tube). Dont have any idea either why it fishtails.
Edwin
