RE: Hangar 9 P-40 Warhawk
Tower Hobbies
Logged in as Guest
Users viewing this topic: Old Navy Flyer
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Hangar 9 P-40 Warhawk
Page: <<   < prev  24 25 26 27 28 [29] 30 31 32 33   next >   >>
Login
RE: Hangar 9 P-40 Warhawk - 10/26/2007 1:29:45 PM
chuck993
Status: offline
I temporarily set my gear up as fixed gear to fly it, moved the gear forward, doesn't nose over on taxing or landing, flys great!
I have a saito 125 in it, but I am thinking of swapping that out with a Saito 100. I have a OS91 4 stroke or a Saito 100 I can put in it, any recommendations?
The 125 is going in a yak
(in reply to Pa-18cub150)
       Post #: 701
RE: Hangar 9 P-40 Warhawk - 10/26/2007 3:45:49 PM
Edwin
Status: online
I suppose either would work. Did you mount the servos in the back? I mounted mine all up by the cg (made a new servo tray). Balanced with a os91fs with no led. 7lbs 10oz. Flys pretty spirited with that setup. If the servos are in the back you might need some weight up front.
Edwin
(in reply to chuck993)
       Post #: 702
RE: Hangar 9 P-40 Warhawk - 10/26/2007 6:27:58 PM
bigtim
Status: offline
I also have the OS91surpass in mine plenty of power,exhaust exits out the rear of the cowl, right now I am using a MAS14/7 3bl prop its plenty fast and jumps into the air.
servos in the rear of the fuse I did put the battery and reciever forward just behind the fuel tank balanced with the CG at 3 3/8" on the suggestions from this thread and it flys great,
its still a little tipy but as long as I give it a little elevator when on the final roll out I can keep the tail down.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Edwin)
       Post #: 703
RE: Hangar 9 P-40 Warhawk - 11/15/2007 12:38:57 PM
rick at work
Status: offline
Has anyone used an OS 91FX two stroke in this plane with a pitts muffler ? I would like to see some photos of the plane if possible. I have this engine and I am cosidering one of these models if the cowling would not need to be cut out too much to make it work.
THANKS,
Rick
(in reply to bigtim)
       Post #: 704
RE: Hangar 9 P-40 Warhawk - 11/26/2007 6:02:27 PM
BillPTC
Status: offline
I am using Saito 100 and two much engine. I wly it at 1/2 throattle. I would use Saito 91 if I did it again.
Bill PTC
(in reply to rick at work)
       Post #: 705
RE: Hangar 9 P-40 Warhawk - 1/28/2008 4:47:18 AM
rustypep
Status: offline
Well...I finally got my P-40 done. I won't maiden it until the weather breaks in Spring and I find a new field. The same day I made my last post in this forum I took a new job in a new state and started the following day. Six months later I am now completely moved and getting back to working on some planes. My final weight came to 8 lbs. 8.3oz, after all the repairs minus some lead. This was a fixer upper I bought at a local swap. Thanks again to all the great ideas in this forum.
My CG right now is at 3 1/2 inches. I am still debating if I want to move it up or leave it.
Click for fullsize
Click for fullsize
< Message edited by rustypep -- 1/28/2008 4:50:25 AM >
_____________________________
Club Saito Member 354
(in reply to BillPTC)
       Post #: 706
RE: Hangar 9 P-40 Warhawk - 1/28/2008 4:59:15 AM
rustypep
Status: offline
Opps...just noticed I forgot to glue the exhaust stacks to the new cowl so almost but not quite done.
(in reply to rustypep)
       Post #: 707
RE: Hangar 9 P-40 Warhawk - 1/28/2008 10:24:34 AM
LDM
Status: online
Rusty , nice plane , if you want to add some cheap but good Oleo struts , try the new ones offered from HobbyPeople , there $25 for a set for the VQ P40 , should work fine on this plane
LDM
       Post #: 708
RE: Hangar 9 P-40 Warhawk - 1/28/2008 10:54:07 AM
BOLT
Status: offline
Your spinner looks great, where did you got it from?
Blessed is the man who has a hobby for he has two worlds in which to live.
(in reply to LDM)
       Post #: 709
RE: Hangar 9 P-40 Warhawk - 1/29/2008 3:04:29 AM
rustypep
Status: offline
I will have to check out those struts LDM. Bolt, the spinner is an old CB Associates P-40 spinner that is now sold by MECOA. It came with the plane. Check out mecoa.com. Thanks for the comments guys.
(in reply to BOLT)
       Post #: 710
RE: Hangar 9 P-40 Warhawk - 1/29/2008 4:35:46 AM
bigtim
Status: offline
another spinner option is one I got from ebay but have since gotten a 2blade version as well from them, its polished aluminum but could be scuffed and painted as well http://www.racingdevil.com/product.php?category_id=105 for 20$ they look pretty good as well.
Click for fullsize
       Post #: 711
RE: Hangar 9 P-40 Warhawk - 1/29/2008 1:49:51 PM
Edwin
Status: online
I have one of those spinners from racingdevil too. A pretty good bargin. After a few years of flying mine, I'm about fed up with the retracts. Too much maintenance to keep them working right. The plane is retired for awhile till I can get some sierra's to put in. Or maybe I'll just sell it at the next swapmeet and get another brand P-40. Either way, I'll still use sierra retracts.
Edwin
       Post #: 712
RE: Hangar 9 P-40 Warhawk - 1/29/2008 10:15:38 PM
LDM
Status: online
Edwin , I am on my third h9 love them all and always used CJ gear , I will now go to sierra , no big hatred on CJ just tired of tinkering with the weak struts , otherwise they have been very good to me ,
My question for you was I just got these VQ struts , was going to try them on my new H9 corsair with stock H9 gear , are you saying the stock H9 gear is a pain ???? can you or anyone explane your experience with the stock gear and also I fly off of grass
LDM
(in reply to Edwin)
       Post #: 713
RE: Hangar 9 P-40 Warhawk - 1/29/2008 11:22:20 PM
bigtim
Status: offline
I fly off astro turf so I have limited expierence with a grass surface,but the stock gear seem to get out of adjustment after about 5 flights or so,mainly with the ball link that is attached to the struts moves a little bit and throws the wheels out of strait and true,I just need to file a flat spot and use some lock tite on the set screw which I havent gotten to.
I also had trouble with the ball links they would pop out if I came in a little hard and fold,this was quite a while ago Horizon sent me some of the new ones and it hasn't happened since apparently horizon also corrected this problem.
when I first flew my P-40 the struts were about as soft as can be, and bent on me when I made a rough landing on the side of our runway which is not smooth at all, when I bent it back strait I tempered the wire( heated the wire with a tourch,not red hot but enough to make water sizzle) it stiffened the strut and made it alot less flexable,so I did the other side seemed to help alot,since then I have had the recomendation to cool metal in oil rather than water it tempers the metal less abruptly.
I also did it to my H-9 mustang struts,which had the softest wire for gear leggs, they were also helped out quite a bit
(in reply to LDM)
