seanychen
MI, USA Status: offline
quote:
ORIGINAL: RCKen I've got a real quick question for the group here. I'm getting ready to do the Hanger 9 P-40 with a Saito 100 in it. I see in all the ads and a lot of pictures here that people are using a red spinner with a 3 blade prop, and have also seen a red spinner with a 2 blade APC prop. Couple of questions. What manufacturer spinner is every body using for the red spinner that seems to have an aluminum backplate? What prop combinations is everybody using on this motor/plane? 2 blade? 3 blade? thanks in advance. Hello, I got a Pro-spin 3.5" 3-blade spinner, which is lathed from bar stock aluminum. Knowing I will be using YS 110 4-stroke on it, I doubt a plastic spinner will last very long. I plan to use Graupner 14x7 3-blade prop. With Saito 100, you can probably use the Graupner 14x7 3-blade. It has about the same load as APC 15x8, which is just a tad much for the Saito 100. But I think the 100 is able to swing it at around 9000 rpm w/ 30% nitro fuel. Dai, I have not seen the CMP P-40 in real life. Judging from the pictures in www.cmpairplane.com the fuselage outline looks good, at least it seems larger proportionally compared with the H9 P-40, which looks a little narrow. As for their decal, if it's like their Zero, it's not impregnated. You have to apply it yourself. And there is no clear coat one way or another. At any rate, you know who not to get the new CMP P-40 from...
_____________________________
E_Total = M*G*H + 1/2 M*V^2 When H=0, all of airplane's velocity becomes crash energy!
