RC Specialties
LA, USA Status: offline
quote:
ORIGINAL: FlymoreRC Predman, Glad to hear your exhaust is working out for you. I'm watching Keleo for when the Hanger 9 P40 comes back into inventory. I have one of his OS70 Pitts exhaust on my 1/5 Sig Cub, and the sound and look are super. Question: what, if any, consideration did you have to make when installing the fuel tank? I'm working on that part of the plane now and find the supplied fuel tank will be chafed by the lower two mounting bolts. They poke past the firewall by about 1/4 " and are rubbing on the fuel tank - sure as heck, they'll poke a hole. Thanks, Michael Michael, In those cases where chaffing a hole in the tank is possible, you can get a piece of the thin rubber used to line the craftman tool drawers. Cut a square for the front of the tank, cut out a hole and you have instant insulation. I bond it to the tank with silicone adhesive. I would trim the bolts as mentioned. Jim
_____________________________
RC Specialties, LLC "Home of the TurboHeader Muffler"
