JohnBuckner
Joined: 12/23/2001 From: Kingman, AZ, USA Status: online
Sounds as though then that they are flying around the rear most limits and its always better to shoot initially for the suggested CG like you are doing. I am making the assumption you are inverting the model on your CG machine for the check. Just another thought is it possible that figure is what is intended with the gear down and you are balancing with the gear retracted as that will make quiet a difference. With all that straightened out and its still tailheavy, if it is not already there the battery should be moved into the tank compartment, I,d be willing to bet it can be fitted under the tank. Only then would I start to add weight on the firewall under the engine where you could find room. John
_____________________________
"Keep your controllines tight"
