RE: Nitro Engine Care And Breaking In/Starting Instructions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: Nitro Engine Care And Breaking In/Starting Instructions Page: <<   < prev  2 3 4 5 6 7 8 9 [10] 11   next >   >>
Login
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 1/27/2008 4:35:15 PM
Johncindy
Status: offline
hi
i have an acme NB16 and broke it in by starting it and letting it idle for 3 tanks
then after 3 when i started my fourth, i gave it small amounts of throttle until break in was done at 6 tanks
was this a good method of breaking it in?
(in reply to Fuelman)
       Post #: 226
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 1/28/2008 1:46:46 AM
Status: offline
I prefer not to idle much, but to start to drive around and break-in at varying throttles (WOT not neccessary yet). This way the temperature
builds up faster.
Your engine should be fine. How long an engine lasts depends on how you look after it, not just run-in.
Eg:Use good fuel, clean filter(s), tune it correctly, don't rev-out for long periods.
I buy my fuel from a shop next to an rc racetrack. The shop sells quality items (novarossi,rb,serpent..)and the owner and his customers race
at championship levels. If the fuel is good enough for their expensive mills, it's definately good enough for mine.
(in reply to Johncindy)
       Post #: 227
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/28/2008 2:07:42 AM
46u
Status: offline
When breaking in my new engines I start them up let them idle for about 30 seconds and drop them on the ground and drive them easy till the temperature gets up to around 200 degrees then I shut it down and put the piston at BDC (Bottom Dead Center). Then I repeat depending on the engine how many times I do this but at least 8 tanks. What I do is basically the heat cycle method. There are other ways of doing it but I have engines with over 9 gallons still running so I will stick with this method.
_____________________________
Rebel Racing, Sponsored by, Byron Fuel Looking for a new engine sponsor!
(in reply to image079)
       Post #: 228
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/28/2008 5:06:00 AM
Status: offline
That is what I do... seems to work.
(in reply to 46u)
       Post #: 229
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 1/30/2008 12:35:59 AM
brandton_phipps@yahoo.com
Status: offline
hello there i need to know i am geting a mt2 with the G3.0 amd where i am it is about 30 or so out side is it safe to breake it in the temp or should i let it worm up a lil
thanks
brandton
POWER IS HOW HARD YOU HIT THE WALL AND TORQUE IS HOW FAR YOU TAKE IT WITH YOU
       Post #: 230
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 12:44:27 AM
46u
Status: offline
Should be OK but I recommend wrapping the head with aluminum foil and preheat it with a heat gun. I always preheat my new engines when breaking them in no matter what the outside temperature is. This helps take stress off the new tight engine.
       Post #: 231
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 12:52:04 AM
Status: offline
thanks i will do that i dont have the car yet my brother is geting it for me but i will do that thanks for the info
brandton
(in reply to 46u)
       Post #: 232
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 1:26:11 AM
46u
Status: offline
I have a HPI MT among many others that has an OS 18 TZ in it.
       Post #: 233
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 1:44:03 AM
Status: offline
i had a mt2 oldschool back in 2000 and loved it it had the T15 and i am hopeing to get the other one tonight if not then i should get it tommorow not having it here now is killing me
(in reply to 46u)
       Post #: 234
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 1:46:32 AM
46u
Status: offline
Mine is a MT 1 ¾!
       Post #: 235
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 1:48:45 AM
Status: offline
you said to rap the head and preheat it do i need to leave it raped when i drive it not to sound stupid
       Post #: 236
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 1:48:54 AM
46u
Status: offline
quote:
ORIGINAL: brandton_phipps@yahoo.com
In 2000 they did not have the MT 2 they had the MT 1 and it came with a 15FE.
< Message edited by 46u -- 1/30/2008 1:49:27 AM >
       Post #: 237
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 1:54:41 AM
46u
Status: offline
Yes keep it wrapped when breaking in or even after break in when it is cold out. You want your engine to run at least 200 degrees. Some even will wrap a sock around it over the aluminum foil if need be. Sorry where I live it does not get real cold for long periods of time. I just broke in my engine on my new Kyosho 09 and it was about 55 degrees out and I still wrapped the head to get the temperatures up do to running so rich at break in settings.
       Post #: 238
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 2:06:37 AM
Status: offline
i live in caldwell id and it is snowing like crazy here that is what i wanted to know what to do but thanks you have been a big help
(in reply to 46u)
       Post #: 239
RE: Nitro Engine Care And Breaking In/Starting Instru... - 1/30/2008 2:17:41 AM
46u
Status: offline
Snow what it that? LOL we only see snow about once every 10 years then it does not last long. Glade to help.
       Post #: 240
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 1/30/2008 2:23:17 AM
tonyedge540
Status: offline
quote:
ORIGINAL: Fuelman
quote:
.. Do i full throttle the fellow or just blip??
Fire it up and drive it. Do not just blip it around the driveway! Yes, some full throttle on the first run is fine, just don't hold it there for long.
quote:
My car engines lasted a few gallons UNTIL I said
