Throttle Assembly Question...
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Throttle Assembly Question...
Page: [1]
Login
Throttle Assembly Question... - 3/21/2005 5:48 AM
PTS
Score: 100
Last Login: 7/4/2009
Status: offline
Hello!
I am finishing up a SIG Kadet Senior ARF w/ a Saito .91. The question is what would be considered a premium throttle setup from the servo to the carb? I hear good and bad about flex cable and good about music wire w/ z-bends. Can someone shed some light on this please...
Perry
Hide Signatures
       Post #: 1
RE: Throttle Assembly Question... - 3/21/2005 6:56 AM
warhwk
Score: 100
Last Login: 6/16/2009
Status: offline
I installed a mini servo up front with a straight rod, but I have had good luck with the stainless braided cable on other planes.
_____________________________
"The probability of survival is inversely proportional to the angle of arrival"
Hide Signatures
(in reply to PTS)
       Post #: 2
RE: Throttle Assembly Question... - 3/21/2005 9:21 AM
Richard L.
Score: 100
Last Login: 12/6/2008
Status: offline
I like using a flexible braided cable inside a nylon tube for my throttle hookup. The nylon tube can have bends in it, but the braided cable still slides freely. Dubro sells this flex cable.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
http://www.WarbirdObsession.com/
Tamiya Panther, Tamiya King Tiger(3), Tamiya Tiger I, HL Tiger(3), HL Panzer III(2), HL Panther, HL Pershing, HL Bulldog, WSN T-34/85, HE Leopard 2A5
Hide Signatures
(in reply to PTS)
       Post #: 3
RE: Throttle Assembly Question... - 3/21/2005 1:43 PM
RCKen
Score: 102
Status: online
I use the braided cable too. Although I don't order it from any of the hobby manufacturers. You can pick it up at wal-mart, lowes, or other hardware stores. You can also get the small tubing to mount it in also. Just make sure that you solder both ends to keep them from fraying. Also, before you slide the cable into the tube squirt a little powdered graphite in the tube to help the cable move more freely.
The take off is optional, but the landing is MANDATORY!!
RCU Forum Manager
AMA# 712539 - www.gettingairborne.com
Hide Signatures
(in reply to Richard L.)
       Post #: 4
RE: Throttle Assembly Question... - 3/21/2005 2:14 PM
bldrums
Score: 100
Last Login: 6/26/2009
Status: offline
My throttle set up on Decathlon w/ Saito 91 is like yours ( 3rd picture ) and I wonder about the way the cable follows the arc of the servo arm. It seems to add a lot of drag as the arm moves from idle to wot.
Do you allow the plastic sleeve to move where it exits the firewall ? My 91s has to be installed close to the fire wall on the Seagull Decath and that leaves very little cable extended from the firewall. This short cable does not have much flexabilty.
. . . . ...........> > >>>geaRUP! >>>>>>>>>>>
Later!
Hide Signatures
(in reply to RCKen)
       Post #: 5
RE: Throttle Assembly Question... - 3/21/2005 2:29 PM
redfox435cat
Score: 100
Last Login: 7/3/2009
Status: offline
I tries the plasic flex stuff once for throll linkage and it meltded , too close to the muffler. opps. A stright shot with music wire, z bent on one end and a quick connect on the servo side seem to do the job the best. The trick is getting the straight shot. Sometimes take a little thought. One resone I quit getting ARF airplanes since they rarley get this right. Flew cable is great also, I just rather not solder, thats just me though
Gravity wins everytime
Hide Signatures
(in reply to PTS)
       Post #: 6
RE: Throttle Assembly Question... - 3/21/2005 3:33 PM
Richard L.
Score: 100
Status: offline
quote:
ORIGINAL: bldrums
I anchored the plastic sleeve at the servo end and firewall. It doesn't move. I tried moving the cable by hand, and there was not much drag as the throttle arm moves from idle to wot.
Hide Signatures
(in reply to bldrums)
       Post #: 7
RE: Throttle Assembly Question... - 3/21/2005 3:44 PM
RCKen
Score: 102
Status: online
Here is how I anchor the tube. I put the braided wire in place inside the tube. I make sure that it is attached to the throttle arm at the carb and connect to the servo. This will give you the location of where the wire is going to be while you are using it. about an inch back from the servo end of the tube (you want it to be able to flex a little bit) I will carve a scrap block of wood to fit between the fuselage side and the tube. Use a sharpened piece of brass tubing to carve out the block to the tube fits into the block of wood. I then use 5 minute epoxy to glue it all into place. Let me know if you have any questions, if you do I'll get a plane down this evening and take a picture of how I install it.
Hope this helps.
RCU Forum Manager
Hide Signatures
       Post #: 8
RE: Throttle Assembly Question... - 3/21/2005 5:50 PM
Richard L.
Score: 100
Status: offline
That's similiar to what I did in Post #3 above (see pictures). I also made sure that the plastic sleeve at the servo end was at the same height as the EZ connector on the servo arm.
Hide Signatures
(in reply to RCKen)
       Post #: 9
RE: Throttle Assembly Question... - 3/21/2005 8:13 PM
bldrums
Score: 100
Status: offline
Thanks guys!!
Im probably way off the thread but, how do I determine the CG on the Stock Stryker. I have the combat module to account for. And secondly, what will the CG on the bare foam model be before installing anything??
New Foam Freak,
Bill
Later!
Hide Signatures
       Post #: 10
RE: Throttle Assembly Question... - 3/21/2005 9:32 PM
Richard L.
Score: 100
Status: offline
quote:
ORIGINAL: bldrums
It's probably a good idea to start another thread.
Hide Signatures
       Post #: 11
RE: Throttle Assembly Question... - 3/21/2005 9:47 PM
bldrums
Score: 100
Status: offline
You are right. I will search first and then if no luck :
new thread going up " Stryker CG location "
thanks
Bill
Later!
Hide Signatures
       Post #: 12
RE: Throttle Assembly Question... - 3/22/2005 1:42 AM
flipstart
Score: 100
Status: offline
On Saito 4S installations I have had the smoothest operating throttle setup by using music wire with sleeve-let the wire go past the throttle hook up about 2 inches - make two 90 bends 1/2"-3/4" apart and attach to throttle on front side. You have to plan ahead for the throttle wire to line up properly but the extra run of wire makes for a smooth operating setup.
Wish I had thought of this idea but it has been posted many times as a good way to hook up a throttle on 4S due to short distance to fire wall.
REAL AIRPLANES HAVE MACHINE GUNS
Hide Signatures
       Post #: 13
RE: Throttle Assembly Question... - 3/22/2005 2:23 AM
saramos
Score: 100
Status: offline
Using a stranded cable inside nylon tube will allow easier routing around engine mounts and fuel tank. If you have a straight, uninterupted path between the servo and throttle, a wire pushrod will work well. I would not recommend using Z bends on both ends of a wire, but rather a Z bend on the servo end, and a threaded clevis or ball joint on the throttle end. There are two reasons. 1, it will allow you to make adjustments, and 2, I have heard (but not personally witnessed) that the metal-metal connection of the Z bend and throttle arm (or any metal arm) can potentialy cause radio interference.
Scott
Hide Signatures
(in reply to flipstart)
       Post #: 14
RE: Throttle Assembly Question... - 3/22/2005 2:31 AM
bldrums
Score: 100
Status: offline
Thanks for the help on throttle cable installation
Sorry , I have my planes and threads mixed up !!!!!!!!
( is it possible to have too much going on at once in this hobby??) naa
Later!
Hide Signatures
(in reply to saramos)
       Post #: 15
RE: Throttle Assembly Question... - 3/22/2005 5:48 AM
PTS
Score: 100
Status: offline
Thanks for the response fellas! Whats your idea of a flex cable with a ball end and a clasp on the other. The cable would be the sullivan push cable...
Perry
Hide Signatures
       Post #: 16
RE: Throttle Assembly Question... - 3/23/2005 12:10 AM
Gringo Flyer
Score: 100
Status: offline
RCKEN, I am curious where you found the braided cable and the tubing to mount it in.
What department is it found in? What is it used for?
"Courage is being scared to death...and saddling up anyway."---John Wayne
Hide Signatures
(in reply to PTS)
       Post #: 17
RE: Throttle Assembly Question... - 3/23/2005 12:35 AM
redfox435cat
Score: 100
Status: offline
braided cable
here an example
Hide Signatures
(in reply to Gringo Flyer)
       Post #: 18
RE: Throttle Assembly Question... - 3/23/2005 12:56 AM
RCKen
Score: 102
Status: online
Gringo,
you can find both in the hardware deptment. the braided cable is used to hang pictures with.
RCU Forum Manager
Hide Signatures
(in reply to redfox435cat)
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.469RCU1
