Jim D
Joined: 12/5/2001 From: Columbia, TN, USA Status: offline
Two of these now flying in my club. One on a DP Ultimate with Bisson Pitts (ends cut off) with a mejzlik 18x8 and a Perry Pump. The other is on a SIG X300XS with a Bisson Pitts, perry pump and APC 17x8. To put it simply, I WANT ONE. Both planes a completley unlimited in vertical and will climb straight up at a very healthy clip. The guy with the DP Ultimate had been running his for a while and has it well broken in and tuned. It runs like the proverbial swiss watch. Turns the 18x8 Mejzlik a little over 8k on the ground and pulls the DP Utimate with authority. He runs 15% in it, and yes it uses a goodly amount of fuel, but no more than a Saito 180, which likes to gobble 20-30% Nitro to really shine. He simply primes it, puts the ignitor on it and gives it one backflip, it cranks right up. The one on the SIG Extra is pulling the plane well, but does not have much fuel through it yet and he still sorting it out. He just added the pump. Both the Extra and Ultimate force you to put the fuel tank at a lower lever than the carb creating an uphill draw. The one on the Ultimate is probablyt he finest running big glow engine I've ever seen. I'm sure once the owner of the other one gets his broken in and tuned, it will follow suit. For the 1/4 scale aerobatic planes, it deserves a serious consideration. Besides, It's a lot cheaper than a Saito 180 or Moki 180.
_____________________________
Jim Davenport
