cannisters & JB Weld
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> cannisters & JB Weld
Page: [1]
Login
cannisters & JB Weld - 3/22/2005 3:07 AM
xtra 330
Score: 100
Last Login: 6/27/2009
Status: offline
has anyone tried using JB Weld to seal the cut line on a cannister header..ie.Cutting the header to the proper angle to allow the cannister to line up inside the tunnel.Instead of welding the cut...what about using JB Weld.It Says it can take up to 900*F....but my concern is the vibration?
Hide Signatures
       Post #: 1
RE: cannisters & JB Weld - 3/22/2005 3:17 AM
DMcQuinn
Score: 100
Last Login: 6/22/2009
Status: offline
I have used JB Weld to join a broken muffler and the results did not last long. This was aluminum and on a glow engine, but I think your results will be similar. There is just too much vibration to hold up over time.
Hide Signatures
(in reply to xtra 330)
       Post #: 2
RE: cannisters & JB Weld - 3/22/2005 3:38 AM
blkbird68
Score: 100
Last Login: 7/3/2009
Status: offline
I have not had any problems using JB Weld. I have used it on small glow engine mufflers and a header and tuned pipe for a .61, among otherthings. What ever you are oing to weld must be clean and free of any oil, and I have also found that if you "cure" it in an oven at 175 or 200 degrees it seems to produce a stronger bond.
Hide Signatures
       Post #: 3
RE: cannisters & JB Weld - 3/22/2005 2:55 PM
pe reivers
Score: 100
Last Login: 7/4/2009
Status: offline
I use JBweld for combat plane exhaust construction with excellent results.
The join must be absolutely clean, and then sanded with 120-100 grit paper. In addition, a generous metal overlap should be provided where the bond is, so the end result will be as strong as the base metal. If an overlap cannot be created from the original metal, bond a strip of scrap sheet over the seam to provide the lap. These are general rules for bonding metal.
I harden the assemblies in an oven at 100 degrees C.
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik
There is sanctuary in analysis.
Hide Signatures
(in reply to blkbird68)
       Post #: 4
RE: cannisters & JB Weld - 3/22/2005 4:01 PM
Desertrat
Score: 100
Last Login: 1/9/2009
Status: offline
Why not just silver solder it?
Hide Signatures
(in reply to pe reivers)
       Post #: 5
RE: cannisters & JB Weld - 3/22/2005 8:02 PM
pe reivers
Score: 100
Status: offline
Like aluminum? Or when the steel sheet is very thin, which makes brazing not practical. The metal would warp too much.
Hide Signatures
(in reply to Desertrat)
       Post #: 6
RE: cannisters & JB Weld - 3/23/2005 3:28 AM
Desertrat
Score: 100
Status: offline
quote:
ORIGINAL: preivers
Agreed, but if you read his post, its to seal a cut made in the header pipe to align the cannister. Seems to me silver solder would work quite well in this application, much better than JB weld, and just as easy to apply.
Hide Signatures
       Post #: 7
RE: cannisters & JB Weld - 3/23/2005 3:39 PM
pe reivers
Score: 100
Status: offline
You are right. I forgot about the header bit.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
