Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce only !!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce only !!!
Page: [1]
Login
Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce only !!! - 3/22/2005 10:20:00 AM
SpiderJets
Status: offline
Dear Friends,
I just happened to return from Seoul, Korea, where I had dinner with some RC friends affiliated to Kokam, the leading manufacturer of Li-Po cells (and other stuff).
Mr. B.J. Park, who is their factory pilot and the current Korean F3A champ, told me Kokam has just developed a new type of Li-Po cell with the following astonishing characteristics :
Cell : 3.7 V
Capacity : 5 Amps (!!!)
Weight : 60 grams (!!!!) (2,11 ounces)
Discharge : max 20C (but 40 C is now in developement and will be soon tested in R/C)
Charge rate : 1,5 C max
Life span : 500 cycles
He states to fly his new electric F3A plane with an 8S cell pack, can make 3 (three !!!) full pattern F3A flights without recharging, and the batteries do not really get warm.
Someone in Japan experimented with these cells too, and used them in a Byron F-16 with a brushless motor with modified D/F. Take-off weight with batteries etc was 6 kgrs (13.22 lbs)... and he had a static thrust of an unbelievable 6,5 kgrs (14,33 lbs) !!!!!!! during a full throttle time span of 4 minutes. Plane was said to be very fast and sounded like a real turbine jet (large fan revving at 23000 RPM).
I am sure, with this kind of figures, electric flight with these new Li-Po cells might become a real substitute for combustion engines, if not even for gas turbines.
The researchers of Kokam said they are not even by far at the limits of technology in this new field of LiPo yet, and expect to be able to make much better performing cells in the next coming years.
The cells used by Mr. Park should be available in the trade somewhere in 2006, as they are now testing with his help the stability etc of these, but all results so far look excellent.
Unfortunately, I had to return home the very next early morning, otherwise they would have shown me these cells and allowed me to witness some flights at the field.
I really hope they will allow me to take home some next time, for me to try in some of my fun electric indoor models !
Best Regards,
Nicolas GODDEERIS,
SpiderJets.
       Post #: 1
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce on... - 3/22/2005 1:26:53 PM
Silver182
Status: offline
Wow someday an electric turbo Jet unit suppling 30 + pounds of thrust...... almost no throttle lag, realistic sound... the total power package including fuel / LiPo's might weigh as little as 5 lbs the only thing missing would be the heat...times they are changing!
Thanks for the report
Lee
(in reply to SpiderJets)
       Post #: 2
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/22/2005 1:32:55 PM
SJN
Status: offline
There is just something more to it ,flying a controled inferno in the sky, than wizzing around on a battery pack
_____________________________
Sonnich Johannesen
(in reply to Silver182)
       Post #: 3
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/22/2005 2:20:07 PM
EASYTIGER
Status: offline
quote:
ORIGINAL: SJN
BINGO!
Electric may someday SURPASS internal cumbustion in performance.
But it AIN'T the same thing.
I had been dorking around with electric s for a LOOONG time. I have the original Kyosho AP35, and Aristo motors that used saltwater batteries, hectoperms, early astro ferrites, yadda yadda yadda... electric is okay...but it's not the same as glow, diesel, or turbine.
Engines is engines, and they are part of the fun for many, many modellers. Be it a Ceccarelli .005 diesel or a Jetcat P80, if it turns dead dinosaurs into smoke and noise, I LIKE IT.
And electric s are missing part of the buzz. To each his own!
(in reply to SJN)
       Post #: 4
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/22/2005 3:40:18 PM
EddieWeeks
Status: offline
Do you mean 5 A hour... ?.. or maybe 5000 mah.. ?
Eddie Weeks
(in reply to EASYTIGER)
       Post #: 5
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/22/2005 4:15:24 PM
Vincent
Status: offline
Good question Eddie, i was wondering the same thing. Must be 5000ma
Jet noise from an elec?? nah, nothing like a turbine but would much rather listen to an elec prop plane than those 2c bangers.
V..
(in reply to EddieWeeks)
       Post #: 6
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/23/2005 8:23:53 AM
SpiderJets
Status: offline
Sorry for not mentioning correctly : yes it is 5000 MAh !
Best Regards,
Nicolas.
(in reply to Vincent)
       Post #: 7
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/23/2005 1:31:32 PM
Silver182
Status: offline
quote:
ORIGINAL: SJN
Yep, I agree I like our blow torches to be sure.... but I also welcome new technology. Shoot I still will fly a kite from time to time.
Lee
(in reply to SJN)
       Post #: 8
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/23/2005 1:42:18 PM
bcovish
Status: offline
quote:
ORIGINAL: Vincent
Jet noise from an elec?? nah, nothing like a turbine .
Also, maybe someone would make air freshner strips that smell like jet-a and we could hang them around our neck.
Bob-O Austin TX
Sticks and stones may break our bones, but words will break our hearts
       Post #: 9
RE: Revolutionary Li-Po cells of 5 Amps @ 2.11 ounce o... - 3/23/2005 4:36:04 PM
Vincent
Status: offline
If there was some way to get a little jet noise out of those DS-51`s i would build another elec AW ME-262 in a second. You can`t beat the dependability of an elec twin.
V..
(in reply to bcovish)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.625RCU1
