90L muffler riser
Tower Hobbies
Logged in as Guest
  Printable Version
K&B .40 R/C Ball Bearing
Seller:  area51jmitch
Details:   $75.00   |  8/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> 90L muffler riser
Page: [1]
Login
90L muffler riser - 3/25/2005 2:55:19 PM
SitNFly
Status: offline
Hi Bob,
I'm installing a 90L in a Patriot XL and it looks like I could use a pinch more clearance between the fuselage and muffler. Do you make short risers to fit between the engine exhaust flange and muffler? I have the stock (long, red) muffler. Looks like about 1/4" would do it. Thanks for any replies.
       Post #: 1
RE: 90L muffler riser - 3/25/2005 3:41:31 PM
bob27s
Status: offline
Hi,
Thanks for writing,
There are muffler extentions available in 1/4" increments (and I think 1/8" too). This will move the muffler away from the engine, and away from the fuselage. You can order the extension by emailing Dub at jettengr@sbcglobal.net or calling. Comes with screws.
If its real close, the easy way is to stack up 5 or 6 exhaust gaskets (.010" each).
It is a little tight up front, but it will make it without the extension. Just takes a little bit of sand paper and some planning. Some folks have sanded a bit of a clearance for the muffler. Makes for a nice installation. Image here is a typical example.
Bob
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by bob27s -- 3/25/2005 3:57:10 PM >
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to SitNFly)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.188RCU1
