famousdave
Joined: 9/16/2003 From: Bradenton , FL, USA Status: offline
quote:
ORIGINAL: branded I happen to agree with Mr. Marez. The only way to reliably provide for backup is to isolate the packs. Contrary to what Desertpig says the most prevalent mode of failure is a shorted cell, not open. I'm not saying that it never happens but rather packs do fail in the shorted cell mode more often than the open cell (broken tabs) mode. Red, one could argue that adding the additional pack, without regard to the most prevalent mode of failure, increases the chance of experiencing the most prevalent mode of failure by a factor of two times.......in other words you've decresed the reliabilty of the system by adding components that could concievably cause an electrical contention if one or the other fails. That's not what you're looking for, is it? When designing reliabilty into a system one must always consider all modes of failure and then assure that the most likely is covered. Simply plugging another pack, via a second switch is not covering the most prevalent failure mode. I'm an EE and have much experience with designing redundancy into a system. Branded - If we're going to throw around titles, I'm an EE PhD, electrical and aeronautical engineering with a minor in mechanical. I have extensive experience in power system design, including battery subsystems. I have performed very sophisticated ESS and HALT tests on many types of battery cells. In the majority of "in use" failures cells increase in resistance or fail open - far more often than they short. You see this in reduced capacity or a slow degradation of the batteries ability to deliver current (i.e. hitting the wall) Without getting technical - Red's explanation above explains it perfectly. This holds true in the batteries used in full scale aircraft, automotive, cellular phones, back up power inverters, rechargeable consumer devices and just about everywhere else batteries are used. Perhaps there is something special about the cells in our flight packs? Doubt it. In mechanical battery banks (i.e. assembled packs) the prevailing failure mode was an open pack (not an open cell) due to failure of the mechanical bond (i.e. weld) of the tabs or wiring. While I agree I may have used a blanket statement above without offering any data - I have found no merit whatsoever in using a battery backer or sharing device as long as both packs are routinely checked, in the same capacity, and charged in a similar fashion using a gang charger. I have in fact seen them create more problems than they solve, hence my statement. If you want to use different capacity batteries or different technologies, then maybe I can see using it. I wasn't trying to start a p'ing match, just trying to offer up a biased opinion - how's that for piling it higher and deeper! DP
< Message edited by desertpig -- 3/25/2005 5:16:51 PM >
