Your Favorite Monitor for AFPD?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Your Favorite Monitor for AFPD?
Page: [1]
Login
Your Favorite Monitor for AFPD? - 3/25/2005 9:39:02 PM
Joe Kelley
Status: offline
I am building a computer for AFPD and ordered AFPD today. I got an ATI 9800 pro 128 for the machine. Could anyone tell me what they are using for a monitor and what is their favorite? I prefer an LCD and have heard good things about the hundai LCDs. I am open to looking at CRTs. What is the naitive resolutions for AFPD? Is a 16x9 aspect better?
Joe
       Post #: 1
RE: Your Favorite Monitor for AFPD? - 3/25/2005 9:41:21 PM
Ian.W
Status: offline
get a progector so you can fly like their the right size
_____________________________
Ian Watson
Team Flightpower
(in reply to Joe Kelley)
       Post #: 2
RE: Your Favorite Monitor for AFPD? - 3/25/2005 9:48:05 PM
azfly4fun
Status: offline
Hey WOW good Idea. I have portal LCD projectors at work that I can sneak out. Haa Haa it pays to be an IT Person.
(in reply to Ian.W)
       Post #: 3
RE: Your Favorite Monitor for AFPD? - 3/25/2005 11:14:50 PM
thundervee
Status: offline
I use a MAG LCD monitor and it is cheap in price
(in reply to azfly4fun)
       Post #: 4
RE: Your Favorite Monitor for AFPD? - 3/26/2005 1:25:10 AM
Joe Kelley
Status: offline
Mag? I can't seem to find them. EE, you are straight on track! I'd like it as real as possible.
I like this http://www.3gplaza.com/estore/control/Computer3G/productdetails?id=35043
Joe
(in reply to thundervee)
       Post #: 5
RE: Your Favorite Monitor for AFPD? - 3/26/2005 1:49:26 AM
tukkus
Status: offline
quote:
ORIGINAL: Goekeli
Joe
I don't see anything in those specs about a response time...for lcd's you want a maximum of 16ms anything over isn't worth getting for gaming and sims. Another thing to look at is the pixel pitch...it's over .29 which basically means that the pictures or frames wont have as much detail to them as with a lower pitch...most decent crt's have a .25 or lower pitch and the better ones have.24 and it's rare to see them any lower than that.
I guess it depends on serious oyu are about the graphics on your monitor...right now the crt's still have the lead on lcd's for overall picture quality but the lcd's are catching up but they are not there yet.
This is a HOBBY so we don't need no steeenkin' reasons to use four stroke engines.
       Post #: 6
RE: Your Favorite Monitor for AFPD? - 3/26/2005 4:53:04 AM
Scott G
Status: offline
I run it on a 22" Mitsubishi CRT. I have been waiting for a large LCD to get a reasonable refresh rate but haven't seen one yet. If you don't mind a smallish one (17" you can get <17ms refresh. I have run it on my 55 inch HD TV which has a 15 Pin Analog input. That pretty much rocks... It makes me want to get a cheaper computer that is always hooked up to it.
scott.
       Post #: 7
RE: Your Favorite Monitor for AFPD? - 3/26/2005 5:11:22 AM
m00m00
Status: offline
The one show on that link is Hyundai L90D+. It has 8ms respond time. As fast as you can get on a 19' consumer LCD today. The older L90D has 25ms respond time
(in reply to tukkus)
       Post #: 8
RE: Your Favorite Monitor for AFPD? - 3/26/2005 4:06:48 PM
Joe Kelley
Status: offline
The L90D+ is really my choice at this point for an LCD. What resoultion are you CRT guys running at?
ImageQuest L90D+ 19" LCD Monitor w/ Speakers, 8ms and DVI –RETAIL
Model# L90D+
Specifications:
Panel Type: A-Si TFT Active Matrix
Native Resolution: SXGA (1280 x 1024)
Pixel Pitch: 0.294 mm
Brightness: 300 cd/m2
Contrast Ratio: 700:1
Response Time: 8ms
View Angle: 150° / 135° (Horizontal / Vertical)
Input Connectors: 15-pin D-sub, DVI-D, Audio in
Features: Built-in 2x 2w speakers & Headphone out; Adjustable Pivot & Tilt/Height Stand
Dimensions & Weight: 16.3" x 17.1 x 7.9" (WxHxD), 12.3 lbs
Is the pixel pitch ok at 0.294?
Joe
(in reply to m00m00)
       Post #: 9
RE: Your Favorite Monitor for AFPD? - 3/26/2005 4:32:24 PM
GCL
Status: offline
Got a 3 monitor (CRT) set up using 2 for AFPD and other for whatever. LCD would be nicer, lower power requirements, low profile, etc.
Once these go, be replacing one at a time with 17"-19" inchers. For now, it's working great. Multiple monitors is the way to go !
Great Sim (AFPD) by the way, an enhancement over my EasyFly Sim.
Click to see fullsize image.
Click for fullsize
       Post #: 10
RE: Your Favorite Monitor for AFPD? - 3/26/2005 4:41:54 PM
Scott G
Status: offline
Apparently my information is dated... here is a 20" with a 16 ms response.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=180735&Tab=2&NoMapp=0
If my CRT ever dies something like this will replace it.
scott.
       Post #: 11
RE: Your Favorite Monitor for AFPD? - 3/26/2005 11:03:46 PM
m00m00
Status: offline
.294 for pixel pitch for 19"lcd is fine for games. Most of today's consumer 19" lcd is the same pixel pitch. Just go to a retail shop to check them out see if the dot ptich bothers you. In any worse case, just put the LCD a bit further away from you on the desk
If you can wait for a few more years, we may started to see hi-definition lcd on desktop. HD LCDs are mostly for notebooks these days.
< Message edited by m00m00 -- 3/26/2005 11:23:20 PM >
       Post #: 12
RE: Your Favorite Monitor for AFPD? - 3/26/2005 11:27:39 PM
Mudsurfer1234
Status: offline
about the big pixel things makin the edges blocky,
some video cards have Anti-aliasing on them, i turned that on for FS2004, made everything look alot better. The whole picture seems better,
but don't put it on too much or your computer will be very slow.
If you right click on the desktop, go to properties, then settings then advanced, and there should be a tab with your video card on it, and if you find Performance and Quality, there should be some bars that say anti-aliasing. If it is checked "Application Controlled" and you don't like how it is, uncheck the box and move the slider to the first notch, try it, and if you want more, move to next notch, etc. But it might get slower and slower if you make it too much.
Scott
Scott Shoemaker
       Post #: 13
RE: Your Favorite Monitor for AFPD? - 3/27/2005 5:20:51 PM
Joe Kelley
Status: offline
Thanks Scott for that info about shaders. That might be a very helpful tweek.
Here is more info about the monitor that I might like to get. Any feedback>?
http://www.hyundaiq.com/pro_spec_l90d+.asp
Joe
(in reply to Mudsurfer1234)
       Post #: 14
RE: Your Favorite Monitor for AFPD? - 3/29/2005 7:21:26 AM
mauiglide
Status: offline
I just got my commander version and I'm using a Dell 2005FPW LCD wide view monitor. Color and graphics is great. Much more field of view than my 19" CRT monitor.
