Magnum .91FS!
Tower Hobbies
Logged in as Guest
  Printable Version
JMP Firebird RTF - RTF
Seller:  volkan
Details:   $16,000.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> Magnum .91FS!
Page: [1] 2   next >   >>
Login
Magnum .91FS! - 3/26/2005 5:44:40 PM
Cogburn
Status: offline
Just got done running in my new magnum .91fs. 150$ on sale at tower! Adjusted the valves and tried a few props. Here's what i'm getting!
39'f , 30.15"pressure
15% omega with 2% castor added
11x9 apc 11600rpm 1.47hp
12x8k ma 10650rpm 1.43hp
14x6k ma 10250rpm 1.77hp
Peaked
HP from thrusthp
These things must fall off fast after 10000rpm.
       Post #: 1
RE: Magnum .91FS! - 3/31/2005 4:51:04 PM
bako
Status: offline
don't trust thrusthp calculator.
I have same engine, running on 5%nitro and 18% castor
here are some results
MA 13X8k 8.3lb
MA 13X8 3blade same, but more speed
top flight 15X6 9.7 lb
(in reply to Cogburn)
       Post #: 2
RE: Magnum .91FS! - 4/14/2005 11:13:41 PM
Dart373
Status: offline
I dont touch the valves. I ran 2 tanks through my $149 tower motor too! I put a Master Airscrew 14x6 and pulled consistently 10,500 static. I put a 15x6 APC on it and pulled 8900. This is with Cool Power 30% Heli. This motor is a hog man, I love it.
_____________________________
Where there is confusion, there is profit.
AMA # 403098
(in reply to bako)
       Post #: 3
RE: Magnum .91FS! - 4/28/2005 5:35:26 AM
w8ye
Status: offline
I ran mine a couple years ago and was 9500 with a 14-8 APC 1,100' @40F.
It was stronger than my OS 91 Surpass I which was 9400 with a 14-6.
Saito 80 was 9200 with a 14-6.
All same day with Omega 10%
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Dart373)
       Post #: 4
RE: Magnum .91FS! - 5/9/2005 3:49:55 AM
Dart373
Status: offline
Now 3 gallons through my Magnum .91 for $149 on 30% Heli..... I spin an APC 15x6 at 10,000 even. This motor is incredible. Stronger than my newer .91 OS Max!!
AMA # 403098
(in reply to w8ye)
       Post #: 5
RE: Magnum .91FS! - 5/12/2005 6:25:33 AM
bako
Status: offline
thats joke yea? how can 91 magnum spit 15X6 on 10k? I can't believe. check thrust or recheck tchometer. if it'sso, lets god be with u. just wonderfull
       Post #: 6
RE: Magnum .91FS! - 5/12/2005 11:36:48 PM
Dart373
Status: offline
It the 2nd one I have that turns a 15x4 or 6 at static 10,000. I have a Magnum tac and a Glow Bee tach. Both the same. The motor is screaming, I believe it. I will get some vid clips up soon. Take in mind, I run 30% nitro too... I run them rich, always run afterrun oil, and let the good times roll. Its 3D, So I dont need to wind them up, but they will!
AMA # 403098
(in reply to bako)
       Post #: 7
RE: Magnum .91FS! - 5/19/2005 3:39:58 AM
RCAddiction
Status: offline
14x6 APC 9900 rpm on Wildcat 15% full synthetic
Lee
       Post #: 8
RE: Magnum .91FS! - 11/21/2005 11:59:36 AM
Gringo Flyer
Status: offline
HOw long after break in does it take to get to these rpm´s
I was breaking mine in yesterday and with a 14X6 MA prop and 10% fuel I was getting around 7500. It was super rich but I cant see another 2500 RPM´s coming out of this engine.
"Courage is being scared to death...and saddling up anyway."---John Wayne
(in reply to RCAddiction)
       Post #: 9
RE: Magnum .91FS! - 11/21/2005 12:07:57 PM
Gringo Flyer
Status: offline
I just looked through some tach readings on other four strokes and you guys are getting close to the same readings that guys are reporting on Saito 100.
I just dont see how that is possible. Am I the only one not getting huge numbers on a Magnum 91?
(in reply to Gringo Flyer)
       Post #: 10
RE: Magnum .91FS! - 11/22/2005 6:25:06 PM
seanychen
Status: offline
High nitro helps a lot in 4-stroke engines nowadays. Usually you can get 500+ rpm gain going from 15% nitro to 30% nitro.
Having said that, the Saito 100 and Magnum 91 4-stroke differ in power by about 500 rpm on the same prop and same nitro. So I can believe that Magnum 91 on 30% nitro will catch up with Saito 100 on 15% nitro, if both use the same prop that's within comfortable range of the 91. However, running expensive 30% nitro fuel on a Magnum sort of defeats the benefit of Magnum's economy. I've found that 20/20 fuel is a good compromise between fuel cost and performance.
Saito 100 will out-pull a 4-stroke 91 significantly when you go to larger prop, like APC 16x4W.
E_Total = M*G*H + 1/2 M*V^2
When H=0, all of airplane's velocity becomes crash energy!
       Post #: 11
RE: Magnum .91FS! - 11/23/2005 12:56:12 PM
Sport_Pilot
Status: offline
I think you will lose a couple of hundered Revs when it is over 80 degrees out. Anybody rememember what they were getting last summer?
(in reply to seanychen)
       Post #: 12
RE: Magnum .91FS! - 11/23/2005 10:22:21 PM
Gringo Flyer
Status: offline
Over 80 degrees. We hardly fly when its under 95!
(in reply to Sport_Pilot)
       Post #: 13
RE: Magnum .91FS! - 12/13/2005 12:16:54 AM
akschu
Status: offline
Magnum calls for no more than 15% nitro, so what happens when you run 30%? Are any of you running into detonation issues?
       Post #: 14
RE: Magnum .91FS! - 12/13/2005 9:47:00 PM
Harry Lagman
Status: offline
quote:
ORIGINAL: Gringo Volador
Gringo, I'm with you. Some of these numbers are just incredible. I bet some of these guys have got the special "one that got past QA" car that does 1000 mpg too.
I mean...., one guys gets 10,000 with an "APC 15x4 or a 15x6". Well which one - or were they the same load?
Also, 9500 with an APC 14x8 on 10% nitro. This is not only at least 600 rpm stronger than any OS, Saito or TT .91 I've ever tested (and I've tached a few now) but is more than 200 rpm stronger than my Saito FA100 can get on 20% nitro.
I wish some guys would take more care when reporting rpms.
