Sport_Pilot
GA, USA Status: offline
[QUOTE]Originally posted by Ed Smith Now that is interesting. Cast iron is not considered a hard material. Every cast iron piston/steel liner engine I ever owned had a hardened steel liner. Is Enya doing something different? Ed S [/QUOTE] Wrong, Cast iron is considered a hard material, not as hard as hardened tool steel but much harder than mild steel. Cast iron has an excess of carbon, so much that pure carbon is found between the crystals of iron and other metals. More carbon the harder the metal. The globules of carbon is why cast iron goes clunk when you hit it with a hammer vs steel which will ring. During the time that most engines were lapped steel and iron many companies made their sleeves from leaded steel, one of the softer steel alloys, but they broke in easily and with lots of oil and little dirt would last a while. Enya, Fox, and other high quality engines used a harder steel that was a tad softer than the cast iron piston. Not hard enough for an engineer to call it a hardened steel liner (which technically they are not), but since it was harder than competition the manufactures could claim they were hard steel. If you ever wear one out you will see that the liner wears more than the piston.
