engine dilema
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> engine dilema Page: [1]
Login
engine dilema - 3/30/2005 4:28:44 PM
gnirwin
Status: offline
I crashed my 4 star 60 lst night and do want to build another, at the same time I've already bought a Hog Bipe and was getting ready to start the build soon. I was planning on putting my ST 75 into the hog bipe but now I can choose between it or the OS 91 FS pumped from my 4 star. I love the way the 4 stroke flies the 4 star and have never flown a Hog Bipe. If you had the choice what would you do?
_____________________________
even a nut can find a blind squirrel every now and then
       Post #: 1
RE: engine dilema - 3/30/2005 5:04:36 PM
FLYBOY
Status: offline
Simple, the ST-75, but then I can't stand four strokes. I like the 2 strokes better. Have a few fours, don't fly them much.
Either one would power it fine though, put the one in that you like the best.
Fly it till the wings come off.
(in reply to gnirwin)
       Post #: 2
RE: engine dilema - 4/1/2005 1:27:54 PM
britbrat
Status: offline
Either one will do nicely. You might think about the next plane in your future & which engine will suit it -- that will determine which engine goes in the bipe.
(in reply to FLYBOY)
       Post #: 3
RE: engine dilema - 4/1/2005 1:51:22 PM
piper_chuck
Status: offline
Bipes sound so much better with a 4 stroke.
AMA 87959, IMPBA 19650 CD, IBDBG #2, local 12
There's A Reason I'm Behind You. You're About To Be Lapped!!!
       Post #: 4
RE: engine dilema - 4/1/2005 2:54:01 PM
Mustang Man-RCU
Status: offline
Everything sounds so much better with four strokes (hee hee hee)
Take-off's are optional.....Landing's are mandatory.
(in reply to piper_chuck)
       Post #: 5
RE: engine dilema - 4/1/2005 3:50:12 PM
hookedonrc
Status: offline
I am in the midst of building a Hog Bipe and chose the Saito 100. It was down to an OS91 surpass, or the Saito, and I chose the Saito because I wanted the Golden Knight version. If you want to see how it is going, I am doing the Hog Bipe build thread in the kit forum. You will probably run into the problems that I have and find the the carb/needle valve will need reversing. This puts the throttle cable in the center of the fuse, but it can be set up that way. You can PM me if you end up choosing the Saito and I can take pics of the install if you need.
My signature would be much more clever than this, but it is all of the characters that I am allowed to post as a basic membe
(in reply to Mustang Man-RCU)
       Post #: 6
RE: engine dilema - 4/1/2005 8:44:15 PM
Campy
Status: offline
The latest issue of "Fly RC" has an article on the 4* 60 with a 91 4s in it. The magizine said "The 4* 60 and the 91 4s were made for each other".
(in reply to hookedonrc)
       Post #: 7
RE: engine dilema - 4/1/2005 11:13:12 PM
Volfy
Status: offline
Unless you modified it, the Hog Bipe is an open-cowl exposed engine sport plane. I would use the ST75 because of that. Save the 91 4stroke for a cowled airplane.
Si vis pacem, para bellum.
(in reply to Campy)
       Post #: 8
RE: engine dilema - 4/12/2005 2:44:32 AM
escipion
Status: offline
I've seen the hog bipe with the Saito and really flies great
(in reply to Volfy)
       Post #: 9
RE: engine dilema - 4/12/2005 4:58:53 PM
MinnFlyer
Status: offline
quote:
ORIGINAL: FLYBOY
I just lost a lot of respect for you Ed
Check your local ordinances... In some states it's ILLEGAL to put a 2-Stroke in a Bipe (Or at least it SHOULD be!)
4-Stroke in the Sig Pig and 2-Stroke in the 4*
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
       Post #: 10
RE: engine dilema - 4/12/2005 5:42:38 PM
piper_chuck
Status: offline
quote:
ORIGINAL: MinnFlyer
Don't those ordinances also include Cubs?
(in reply to MinnFlyer)
       Post #: 11
RE: engine dilema - 4/12/2005 9:44:39 PM
MinnFlyer
Status: offline
You're right Chuck - Bipes, Cubs and War Birds...
and using anything bigger than 60 size 2-stroke is a misdemenor
Mike B.
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
